What are these relays for?
Old Aug 4, 2007 | 01:52 PM
  #16
There are starter and VATS schematics on my Tech Page to assist you in troubleshooting.
Old Aug 4, 2007 | 02:10 PM
  #17
87camracer's Avatar
Have you ever seen a problem that is vats related where the security light only comes on while the key is turned to start? It will not come on with the key to the run position, and will only stay on for 5 seconds or so with the key turned to run. If you disconnect the vats harness under the column, the light will still only come on with the key turned forward but will flash instead of stay solid.
I am wondering if this is a bad key cylinder because it does nothing when you turn the key to the accessory mode (put key in and turn backwards).
Old Aug 4, 2007 | 02:55 PM
  #18
87camracer's Avatar
Originally Posted by 87camracer
Have you ever seen a problem that is vats related where the security light only comes on while the key is turned to run? It will not come on with the key to the run position, and will only stay on for 5 seconds or so with the key turned to run. If you disconnect the vats harness under the column, the light will still only come on with the key turned forward but will flash instead of stay solid.
OK well I stand corrected, the car DOES have accessory mode now.
Old Aug 4, 2007 | 03:05 PM
  #19
I obviously have not seen or read about every problem there is with VATS and can't be expected to have an answer for everyone, but if you don't logically troubleshoot it, you will never find the problem.
It is also hard to follow when you say:
... where the security light only comes on while the key is turned to run? It will not come on with the key to the run position, and will only stay on for 5 seconds or so with the key turned to run.
One statement seems to contradict the other.
Old Aug 4, 2007 | 03:54 PM
  #20
87camracer's Avatar
Yeah that was my mistake, it shouldn't say run there. I will go back and edit that.
We are slowly making our way through the troubleshooting but I was just hoping you or someone else had encountered something like that before and could steer us in a direction that would bypass things that aren't related.
Aaront810
Aug 29, 2020 09:34 PM
OutlawPerforman
Oct 30, 2017 05:40 PM
Jeff1904
Jun 5, 2016 05:00 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
jerrysims71
Aug 15, 2015 12:47 PM
