what taper is the crank hub cut on?
Old Sep 4, 2004 | 12:42 PM
BMAN'S SCZ's Avatar
Hello guys, I need to know what angle the stock crank hub is cut on so i can fix mine. I spun mine and wore it out. So i am gonna plug, recut and key it. Thanks for any info...John.
Old Sep 4, 2004 | 02:01 PM
Mtrhds94Z's Avatar
Re: what taper is the crank hub cut on?
There is no 'taper'[morse or otherwise] on a crank nose..it's a straight shaft[tho yours may be tapered NOW after much wear..]
I can't find the diameter of the crank nose, but if you have a crankshaft sprocket that should be about the same ID as the hub needs to be..
Old Sep 4, 2004 | 04:49 PM
Yeah, I don't think there is a taper. I bet one of the machine shop "heads" on here could tell you the size you need.
mightymouse383
Jul 20, 2016 07:34 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
