What suspension mods will help me launch?
Old May 26, 2003 | 05:50 PM
94 CAMRO Z28's Avatar
The mods in the sig along with Nitto DRs and I still can launch worth s*it at the track. I want to be able to drop the clutch at 4-5K and let it rip. What will help me out here? Besides some E/T drags, which are next on the list.
Aaron
Old May 26, 2003 | 06:13 PM
blownbird01's Avatar
Get an adjustable front strut set up. QA1 makes a very nice set up. Rear lower control arms and an adjustable torque arm will greatly improve traction. Do not over look the most important peice of the traction puzzle: STICKY TIRES!
Old May 26, 2003 | 06:16 PM
I think my Nitto DRs are pretty sticky but when these wear out Im just gonna get 2 seperate rims and mount some Mickey ETs on them for the track. Also, what do you guys think about running V6 springs? Are they worth it?
Aaron
Old May 26, 2003 | 06:32 PM
97chevy383's Avatar
Not a mod but try removing front sway bar it will give you better front to rear weight transfer.Also should take about 30 pounds off the front of the car hope this helps.
Old May 26, 2003 | 10:07 PM
I've tried before and could never get the bolts loose. I'll try harder next time before going to the track. See if it helps at all
Aaron
Old May 26, 2003 | 10:24 PM
Dragon Racing's Avatar
Just soak the bolts with alot of PB Blaster. It took me awhile to get the bolts broke loose, but they finally did after about half a can.
Old May 26, 2003 | 11:16 PM
Draco's Avatar
Lower Control Arms with poly or spherical bushings, and LCA relocation brackets will help keep the rear planted and reduce wheel hop.
However if you want to drop the clutch at 4500+ rpm, you will need BFG drag radials at minimum!
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
mrwz28
Jul 8, 2015 09:11 PM
CARiD
Jul 7, 2015 08:19 AM
