what springs for Crane 210/224
Old May 11, 2004 | 11:56 AM
  #16
BUBBA's Avatar
Spring requirements: w/ 1.5RRS
closed 120# @ 1.875
open: 312# @ 1.375
Min. RPM 2000
Max. RPM 6000
Valve Float. 6500
I used REV Springs rated at 550 even though the exh lift w/1.6rr is 553.
I doubt that I will have a problem. Hope not.
Old May 11, 2004 | 01:54 PM
  #17
mastrdrver's Avatar
Have you considered the Comp beehive springs, or are those out of your price range? I know there have been proven gains over "normal" springs.
Old May 11, 2004 | 02:56 PM
  #18
toegead93's Avatar
I'll keep my options open to everything. What kind of gains and is this the Comp Cams 26918 Conical Spring and what components aould you recommend. The 26918's are for LS-1, does that matter?
Old May 11, 2004 | 03:36 PM
  #19
z28poweredlt1's Avatar
just for kicks, i was wondering what the total write up would be on that. If you can let me know becuase Now I'm leaning towards going that route. Numbers look good But i dont know how the Pricing looks. Thanks.
-Mark
Old May 11, 2004 | 04:13 PM
  #20
toegead93's Avatar
it looks like the Comp 918's would be cheaper in the long run. You can use stock retainers and locks. That's a big savings over the Isky springs, where you'll need retainers & locks. Can they use stock GM locator seats?
Old May 11, 2004 | 08:34 PM
  #21
truedualws6's Avatar
-Mark
Here is the total write up on the beehives (if that is what you
were asking):
26915 or 26918 springs depending on the pressure you want.
I think the 26915s are just fine for stock/mild applications.
Comp Press Release
If you want to go with 7 degree hardware:
787-16 retainers
648-16 locks
If you want to go with 10 degree hardware (super locks):
795-16 retainers
611-16 locks (standard), or
614-16 locks (+.050)
Using the standard hardware you should end up with a 1.75"
installed height. With the +.050 super locks you should
get a 1.80" installed height. Depending on your rockers and
lift numbers, a close check of valve stem seal to retainer
clearance and rocker to retainer clearance is warranted.
Also, FYI for a stock spring pocket:
The LT4 spring seats will not work with these springs. The OD
of the seat shoulder is .920" while the ID of the 26915 spring
is .875". The spring does not sit flush with the seat. So far I
have not found an off the shelf seat that will work.
Old May 11, 2004 | 10:16 PM
  #22
Frank95z's Avatar
I've run the Rev springs with stock locaters,Isky 235-D with L98 locaters and the Comp 941's with sucess with the Crane 210/224. I like the Isky springs the best. Call Thunder racing and ask Paul for the combo that Frank95z runs. I shift at 6200 with no problems with these springs. Frank95z
Old May 11, 2004 | 10:47 PM
  #23
Originally posted by Frank95z
I've run the Rev springs with stock locaters,Isky 234-D with L98 locaters and the Comp 941's with sucess with the Crane 210/224. I like the Isky springs the best. Call Thunder racing and ask Paul for the combo that Frank95z runs. I shift at 6200 with no problems with these springs. Frank95z
When you run the Isky 235-D springs with the L98 locators,
what is your installed height? Also, what valve stem seals
do you use and what is the clearance on the exhaust side
at max lift?
Old May 11, 2004 | 10:55 PM
  #24
toegead93's Avatar
how would 1.7"rr's and the comp 918 springs affect performance of this cam? Would it be not necessay/overkill?
Old May 11, 2004 | 11:38 PM
  #25
Frank95z's Avatar
Truedualws6 When I ran the Isky springs and the gm locaters I used the K-line valve stem seals that thunderracing sells. They work great. With stock valves the 235's set up at 1.750 with the gm locaters and no shims. That gives .046 on the exhaust from coilbind. I ran these springs for years with no trouble. I currently run the Comp 941's with a bit more valvespring pressure. No performance increase but i got them at a good price . I shift at 6200 normally,but have run to 6600 with no problems. Good Luck Frank95z
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
nikolt1
Feb 27, 2015 09:10 PM
