What springs? (bolt on only car with 1.6s)
If you just want a nice cheap upgrade the lt4 hotcam springs should be good, i believe they are 100lbs whereas stock is around 80 (like 90% sure), just don't ever run any cam bigger than the hotcam with those springs they are maxed out at .525 lift.
hotcam springs is a common upgrade on a stock motor.
Jul 4, 2005 05:00 PM
