What Springs?
Old Jan 25, 2005 | 08:35 PM
Paul94Z's Avatar
What Springs?
What springs do yall recommend running with the GM847? Also what retainers,locks,locators? Also ill be running 1.6 rockers with this cam whats the max I could get my heads milled before I run into clearance issues with the valves?
Old Jan 25, 2005 | 10:26 PM
blackztpi's Avatar
Re: What Springs?
well, a wise source tells me comp cams 10308-1 spring kit. comes with retainers and locks. these do require .100" longer valves, but thats not a problem if you're buying new valves anyway. I'm going to go with this setup myself.
Old Jan 25, 2005 | 10:57 PM
SStrokerAce's Avatar
Re: What Springs?
K-800's with Ti Retainers...
977's with Ti Retainers....
Comp 26918 Beehives
Those would be what I would look at.
Bret
Old Jan 26, 2005 | 12:13 AM
Paul94Z's Avatar
Re: What Springs?
Yea I already have my valves. I have Ferrera Valves I ordered off of www.cmotorsports.com they are 2.0/1.56. So what springs,locks,retainers,locators should I run?
Old Jan 26, 2005 | 01:18 AM
Re: What Springs?
Depends on the spring. I would make sure you get a machined lock, they cost a little bit more but they don't break.
Bret
Old Jan 27, 2005 | 12:42 AM
Paul94Z's Avatar
Re: What Springs?
Whats a good spring yall recommend I should run? Also what about the milling ? I asked?
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
