what is the specification of the gm847 cam and the le2 cam???'
Old Oct 29, 2006 | 02:08 PM
camarohg's Avatar
hi i need to know what specification those cam have, because i`m planing to put a cam in my lt1 camaro 94 a4 and i don`t know anything about those cams??
Old Oct 29, 2006 | 02:30 PM
jsetzer's Avatar
Call the person that designs the le2 and ask them. You may get rough specs here but lots of time and research went into the le stuff and I dont think you get the specs unless you are a paying customer.
Also a simple search will get your results. Look for gm847 cam card, you will find it.
Old Oct 29, 2006 | 07:19 PM
SStrokerAce's Avatar
Nope not getting any LE specs.... unless you buy it.
It's smaller than the GM847 in some reguards, larger in others.
Basically it's going to make more average TQ and the same HP peak, but work in a lower RPM range.
The bad dude is the LE3 cam on a 355, it likes RPM and takes on the 847 bigtime.
Bret
rojo10956
Classic Engine Tech
Dec 13, 2021 12:17 PM
tnorm077
May 23, 2015 09:10 PM
racecarz28
Mar 30, 2015 09:55 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
LT14LIFE
Feb 9, 2015 09:35 PM
