What spark plugs to use with MSD?
Old Jul 14, 2003 | 06:54 PM
PatriotTA's Avatar
I have heard that you are supposed to use steel plugs with a MSD box because it will give you a better spark. Does anyone know where I can get AC Delco steel plugs? I've only seen platinums around, and they are $6 each. I'll be damned if I'll spend $50 on plugs alone. Who has had good results with what plugs and MSD boxes?
Old Jul 14, 2003 | 07:47 PM
Pandamonkey's Avatar
I use steel splitfires with my box.
I phoned MSD when I installed it becuase I wanted to change the plugs at the same time.
They recommended not going with the platinums because of the lower melting temp of the metal.......
I guess it comes down to that the 6A box is supposed to help prevent plug fouling and if you use platinum they can't garentee the same thing........
I saw a little bit better fuel economy and throttle response with my box - also the car starts up with a flick of the key - no chugging at all.
Old Jul 15, 2003 | 06:50 AM
PatriotTA's Avatar
Cool, thanks for the info.
markzzzz
May 8, 2015 09:21 AM
BLK1997Z28
May 7, 2015 03:01 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
