What spark plugs should I use?
Old Mar 28, 2005 | 07:02 AM
cmking26's Avatar
With my mods in sig what spark plugs should I use and at what gap? Thanks for help
Old Mar 28, 2005 | 10:42 AM
wicked_95z's Avatar
Re: What spark plugs should I use?
I think the NGK TR5's would be good. I run the TR6 for nitrous but the 5's are mainly for N/A motors and I believe they are 1 or 2 steps colder in heat range than stock.
Old Mar 28, 2005 | 10:45 AM
LT1 Bunny's Avatar
I think you should go with a colder plug. I tried A LOT of combinations for my setup and found out that .035 was perfect! Pretty cold plug if you ask me but thats what worked the best. I tried .06,.055,.05,.045, then finally .035. I'm almost tempted to go hotter to .04
Old Mar 28, 2005 | 11:37 AM
wicked_95z's Avatar
.35 is a good starting point. If you raised the CR any with a stock ignition you may want to go .30. If you have a near stock CR and an aftermarket ignition you may try .40 or .45
Old Mar 28, 2005 | 03:09 PM
cmking26's Avatar
I raised the compression just a little and Im using stock ignition other than high output coil. Ill try ngk tr5 at .035 then. Thanks
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
