What spark plugs on LE2
Old Jan 23, 2008 | 08:31 PM
jclark311's Avatar
Hey guys finishing up my LE2 installation, what spark plugs are you running, and why?
Old Jan 23, 2008 | 09:00 PM
slomarao's Avatar
i would always use a ngk plug with an lt1
Old Jan 23, 2008 | 09:21 PM
94zgreenmachine's Avatar
NGK tr55 for mine. Plugs look good.
Old Jan 23, 2008 | 10:12 PM
NightTrain66's Avatar
I have had best luck from Autolite 104's gapped at .035.
Lloyd
Old Jan 24, 2008 | 09:37 AM
RicocheT's Avatar
Lloyd
I use the 104's also. I think I gapped mine at .040 maybe. I can't remember now
Old Jan 24, 2008 | 02:26 PM
remaxracer45's Avatar
i used the 55's on my LE2 WS6 and thats what Lloyd recomends
Old Jan 24, 2008 | 02:35 PM
BUBBA's Avatar
Just curious: why can't you install the plugs before you install the heads?
Old Jan 24, 2008 | 02:40 PM
Javier97Z28's Avatar
Moderator
You can.. but it's a good way to snap them in two when you try to get the headers in.
Old Jan 24, 2008 | 02:48 PM
BUBBA's Avatar
Just wondered---seems like you could put some rubber hose on them to protect them, especially the hard to get at ones. And too, with the heads off one could conceivably index each plug so that the gap would be oriented toward the intake valve prviding a better burn. JMHO
Old Jan 24, 2008 | 03:01 PM
Moderator
Agreed, but with the minimal clearance and the need to get headers in from the bottom sometimes, I can't see being able to do it with the plugs in the way.
Tho indexing the plugs would be nice.
Old Jan 24, 2008 | 04:26 PM
BUBBA's Avatar
Perhaps one could index them and mark them along with any required shims while the heads were off and make sure that they were installed with the correct shims and paint marks when they are installed after the heads were installed and the headers put into their locations. Also if one painted the side of the plug which would indicate the orientation of the gap, then perhaps one could, with some work, install the plugs with the mark aiming at the intake valve. or a least not 180 degrees off.
If they weren't so damn hard to get to and see what you were doing it sure would make life easier.
I believe next time, I will mark all my plugs indicating the gap area and just see how many line up with the int valve when installed, at least for those I could actually see. Maybe I could notch the ones I couldn't so that I cold feel which way they were pointed. Just food for thought.
Old Jan 24, 2008 | 05:31 PM
jclark311's Avatar
Thanks Lloyd, and all others who chimed in.
Old Jan 27, 2008 | 08:03 PM
95Z28ConvtM6's Avatar
Lloyd
Yes, I think .035 -.040" is the ticket, especially with the compression gain with the LE2 head and Impala SS head gaskets. I have mine gapped at .050 (TR55), but had a slight low rpm, light load miss. I just installed a Digital 6 MSD and cleaned it up rather nicely.
jayblev95
Jun 7, 2015 04:04 PM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
