What spark plugs?
Old Apr 25, 2006 | 12:04 PM
CamaroKid_Z28's Avatar
What spark plugs?
i have a 94 Z with only minor bolt ons so far...and i figured that since im putting on a set of headers that its probably worth it to just put on a set of spark plugs while im in there. a while ago i was looking at a set of NGK iriduim's. are they a good set for my car?
Also, what gap should i set? (i know i could easily find this, but its just easier since i know a lot of u guys know it off the top of your head)
Old Apr 25, 2006 | 03:54 PM
2000GTP's Avatar
Re: What spark plugs?
If you don't mind spending 7 bucks a plug, then go for the NGK iridiums if you desire. Otherwise, the regular copper tip NGKs will work just fine as well. If you only have minor bolts ons, then the NGK TR-55 or NGK TR-55IX plugs will work for your application and a good gap would be .050.
Old Apr 25, 2006 | 04:27 PM
BlackScreaminMachine's Avatar
I use NGK's if near stock TR-55's would be fine, if est hp is over 400 flywheel hp NGK TR-6's gapped to the recommended 0.035" would me more then adequte
Old Apr 25, 2006 | 04:50 PM
Quickss96's Avatar
i have a 383 what do you think i should run?
Old Apr 25, 2006 | 05:11 PM
tr-6's
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
