what are some common issues with optispark??
Old Sep 8, 2005 | 01:51 PM
  #16
Z95m6's Avatar
Re: what are some common issues with optispark??
Originally Posted by BlackScreaminMachine
NO RUNNING WATER!! At all!
If you want to clean. Use stuff in a spray bottle such as simple green, purple power, invisble glass..... etc etc and a towel. That should get the bay pretty good. Also under neath, Brake Cleen and a towel to get oil residue etc etc.
93-94 had the unvented unit, its not 100% sealed and moisture can get in and damaged the unit.
If i recall in 95+ LT1's got a vented opti which uses a line that comes from the manifold that sucks out moisture, it helps but again not 100% cure all.
here is a good link so you can see the difference.
http://para.noid.org/~muttvette/opti.html
You can wash your engine you just have to be careful. Don't stick the water hose down by the water pump, but you can wash the top of the engine, shock towers and the under side of the engine with no worries.
rocknroler69
Apr 29, 2015 10:24 PM
ad356
Apr 11, 2015 11:12 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Snoman73
Nov 17, 2014 07:22 PM
