What sized injectors would work for my set-up ??
Old Jul 4, 2004 | 01:09 PM
'93 formy ...'s Avatar
I'll make it short and sweet. I'm in the process of tearing down my LT1 and building up a 396. My goal is to make 500 HP (flywheel). Later add a fogger system which would add an additional 250 just for the hell of it.
What sized fuel injector's would you reccomend for my 500 horse goal?? I've tried variouse different "calculators" on line but have gotton answers rangeing from 30lb all the way to 42lb.
Also, what brand should I get? SLP/Bosh? SVO? MSD? Where's the best place to order them from and should I spend the extra $$ for the "flow-test" set over the standard set?
Thanks.
Old Jul 4, 2004 | 02:14 PM
Josh-'04 GTO's Avatar
30# injectors would probably work, but I'd go with a set of 37# injectors from Racetronix. That would allow you to make 500+hp and still be at 80% duty cycle. It would also allow you to make some additional hp later on and still not run out of injector.
Old Jul 4, 2004 | 02:22 PM
Cool. Thanks. Where can I find these injectors from? I've never heard of Racetronix before. How much for a set?
Old Jul 4, 2004 | 02:23 PM
www.racetronix.com
Old Jul 4, 2004 | 02:25 PM
www.racetronix.com
Yeah, I figured that out but it was too late to delete my post. Thanks again.
Old Jul 4, 2004 | 02:30 PM
I checked them out and the price for the 37lbs injectors seems alright but then I read that you can only get them using PAYPAL. I can't stand PAYPAL and I swore I'd NEVER use it again (too many bad experiences with 'em)
Any other place I can get similar injectors from- preferbly a place I can use my Credit Card?
Old Jul 4, 2004 | 03:05 PM
cliff929's Avatar
Summit has 36lbs svo injectors and maybe a little cheaper too.
Old Jul 4, 2004 | 03:10 PM
Originally posted by '93 formy ...
I checked them out and the pric for the 37lbs injectors seems alright but then I read that you can only get them using PAYPAL. I can't stand PAYPAL and I swore I'd NEVER use it again (too many bad experiences with 'em)
Yeah, I don't trust paypal either. I like LS1 Speed as well:
http://www.ls1speed.com/catagory.cfm?catagory=fuel
HectorM52
Jul 30, 2017 11:46 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Jul 4, 2005 05:00 PM
jim88iroc305
Aug 13, 2002 09:24 PM
