What size throttle body do I need for my setup?
Old Sep 22, 2005 | 09:51 AM
Kurt Crosbie's Avatar
I'm making about 400rwhp.
Is it bottlenecking me at all? I heard that 450fwhp is the limit for the stock tb.
Old Sep 22, 2005 | 10:03 AM
roadtrip120's Avatar
Re: What size throttle body do I need for my setup?
Lloyd recomends a 58mm for his 400rwhp setups. Please tell me that you are not on a stock 48mm with a gm847??
Old Sep 22, 2005 | 10:20 AM
teke184's Avatar
you'd definately benefit from a bigger tb. whether the hassle or not to bore out the intake to accept the 58 is up to you.
i would think the difference between 52 and 58 would be minimal
Old Sep 22, 2005 | 10:24 AM
FastZinTennessee's Avatar
What kind of heads are you running? I didn't see anything listed in your sig.....
Old Sep 22, 2005 | 01:37 PM
lt1 heads and intake, port matched to each other. and home ported heads.
I would like to see dyno results showing that a 48mm tb restricts a 450hp setup.
Old Sep 22, 2005 | 03:04 PM
Z95m6's Avatar
Do you have dyno numbers saying so? If so you must have some pretty good home ported heads.
Old Sep 22, 2005 | 06:45 PM
no dyno numbers yet. thats based off comparison. there are plenty of stock bottom end lt1's making 380rwhp with gm847 and home-ported heads. I've seen guys go 11.5x with stock heads and gm847. I've got 11.3 as opposed to 10.5 compression compared to stock + 3" duals + the home-ported heads. There is no way I should be making less than 400rwhp, unless I had a 12-bolt and auto tranny, which I don't.
Old Sep 22, 2005 | 06:56 PM
Z95m6's Avatar
If all you have is a port match. Thats not really porting at all.
Old Sep 22, 2005 | 06:59 PM
They are not just port-matched. Regardless, like I said, 400rwhp is possible on bone stock heads with an 847.
Old Sep 22, 2005 | 07:14 PM
Z95m6's Avatar
Are you sure? i thought the highest on stock heads was about 358 maybe 360ish.
Old Sep 22, 2005 | 07:18 PM
Stock heads w/ GM847, 400 rwhp is not possible.
Old Sep 22, 2005 | 07:30 PM
joeSS97's Avatar
^^^^ I second that.I would be suprized if you hit 360.
Old Sep 22, 2005 | 07:50 PM
altjar put down 365rwhp through a 12-bolt.
Old Sep 22, 2005 | 08:39 PM
Z95m6's Avatar
http://web.camaross.com/forums/showt...&highlight=847
Old Sep 25, 2005 | 02:05 PM
we're getting a little off topic.
but just fyi, i'm not running a stock bottom end. it's 11.3 compression with forged internals and 6" rods. it's full bolt-on except for the underdrive pulley. plus, i have 3" dual exhuaust.
