What size injectors to run?
Old May 31, 2010 | 05:52 PM
charliediss's Avatar
Second guessing my injector purchase, they are going into a streetable 396, running warlboro 255lph and load leveler...I think I went with Lucas 36#ers, is that sufficient?
Any help would be appreciated.
Thanks, Charlie
Old May 31, 2010 | 07:04 PM
RamAir95TA's Avatar
What kind of HP are you looking at? Flywheel of course.
Old May 31, 2010 | 07:09 PM
Wow I wish I knew for sure right now, but I was told by my machinist/builder that I will be up around 430+ How much water that holds I just don't know. I will be running stock casting trickflow gen Xs with a 236/246 on a 112 LSA bumpstick. I am pretty sure he said that will be RWHP, so what that translates to FWHP, I am not sure.
Thanks!
Charlie
Old May 31, 2010 | 07:48 PM
Ryan94ZA4's Avatar
You should be able to hit those numbers with 36's. I'd just set fuel pressure at 50 psi and you should be fine.
Old May 31, 2010 | 08:03 PM
RamAir95TA's Avatar
430WHP translates to about 520 flywheel. If that's the case, .07 x 520 = 36.4# injectors. I would step up one size and use 42#.
Old May 31, 2010 | 08:42 PM
Great info guys, thanks!
Old Jun 1, 2010 | 05:57 PM
Wild1's Avatar
I would also stay away from the Delphi #38. That is what I went with and they will not offer injector offset values. I regret that and didn't know until after I purchased them.
Racetronix is a good company and you can find others on this board. The Ford SVO seems to be a good injector and they offer data specs for your programmer when you are ready to dyno tune.
Old Jun 1, 2010 | 06:03 PM
Interesting, what do you mean by injector offset values? I am looking at the racetronix, it looks like the better bet for me right now.
Old Jun 1, 2010 | 06:58 PM
Wild1's Avatar
Injector offsets are the variances in time relative to injectors opening and closing cycles. Some injectors open sooner than other brands... Others are later. The programmer can dial in the settings for the new injectors. Also, be sure to get a copy of the original file before programming.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
nophix
Nov 30, 2014 10:26 PM
Wilson
Jul 21, 2002 04:58 PM
