What size injectors?
Old Sep 12, 2005 | 11:01 AM
Black6spdZ's Avatar
I have a built 355 long block and am going to put the LE3 set up on top. I currently have stock injectors and am wondering which to buy, would 36lb be ok because i plan on making it a 396 in the future?
Old Sep 12, 2005 | 11:32 AM
JustNO's Avatar
Re: What size injectors?
36-37 will be ok with LE3 setup, but its all related to Flywheel Horsepower not cubic inch ..
For 480 - 520 flywheel hp 36-37 will be fine..
Old Sep 12, 2005 | 05:14 PM
Admiral94's Avatar
For the 355 the 36 lbs will work just fine. If you build a high RPM 396 then you might need to step up to 42 lbs injectors.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
