what size header bolts? can i use the 1 inch bolts
Old Mar 20, 2008 | 07:41 PM
MonkeyManZ28's Avatar
what size do i need for my flp long tubes, can i use the 1 inch bolts, will they go all th way in ?
Old Mar 20, 2008 | 08:27 PM
MeanGreen97Z's Avatar
1 inch will work fine.
Old Mar 20, 2008 | 08:44 PM
2000GTP's Avatar
Yes, they will work, I would actually recommend those over the 3/4" ones.
Old Mar 20, 2008 | 11:47 PM
jasonface's Avatar
On my heads (LT4) I had to blind tap the holes to get 1" bolts all the way in. They were just barely running out of thread otherwise. The holes were plenty deep, but not threaded all the way. I guess others may be different?
*edit* should also mention the header flanges were 5/16". A 3/8 flange may have worked fine, but it would have been really close.
Old Mar 21, 2008 | 02:48 AM
Sinister95Z's Avatar
When I installed my Pacesetter long tubes, I was told it was a very good idea to use the 1" instead of the 3/4". I think the part number I ordered from Breslin was meant for a big block...
Old Mar 21, 2008 | 08:17 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I used 1" Breslin bolts with my headers. Considering the thickness of the flange and gasket, I wouldn't have felt comfortable with 3/4" bolts.
Old Mar 21, 2008 | 09:26 AM
2000GTP's Avatar
Exactly, the flanges are thick. I originally used 3/4 ARPs, they didn't feel like they had enough bite as they ran out of thread pretty quickly.
Old Mar 21, 2008 | 09:34 AM
caldercay's Avatar
I'd say they *should* work, but that depends upon the size of the flange
used for the FLP's. I'm running 1" on the Kooks, which have a pretty
thick flange. I ran 1" 'socket head' bolts (versus hex-head), and for me,
these are the only way to go - makes tightening the bolts way easier:
http://picasaweb.google.com/calder.c...32328402025650
Old Mar 21, 2008 | 02:42 PM
jasonface's Avatar
I used ARP 1" SS, 12 point, reduced head (5/16") bolts. They look great, and the 5/16" head makes it easy....well, easier to get the wrenches on 'em. Technically, NOTHING is EASY when you're talking about headers on these cars
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
tubby
Oct 13, 2003 09:16 AM
