What size exhaust to run?
Old Apr 20, 2006 | 08:10 AM
Rage's Avatar
I have an LT1 in my IROC and I just installed a set of Hooker LT's. I want to run an X pipe with dynomax bullet mufflers. I'm thinking that if I go with 3" that it will not create enough back pressure. The LT1 is mostly stock for now, but I do plan to run mid 12's with it. So, give me your opinion on what will be best. Thank you.
Old Apr 20, 2006 | 08:13 AM
)2overt SS's Avatar
Re: What size exhaust to run?
If you're tight for ground clearance... I'd go with 2.5".
But if you are planning more power in the future... then 3" sounds good.
Old Apr 20, 2006 | 08:19 AM
2000GTP's Avatar
I wouldn't worry about the backpressure issue, 3" will work fine.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
