what size bolt on stock y pipe??
Old Jan 27, 2004 | 01:19 PM
SiDeWaYZz28's Avatar
hey everybody what size bolt is on a stock y pipe?? the 3 ones on each flange,,,thanks
Old Jan 27, 2004 | 01:38 PM
come on somebody has to know...please help a brotha out
Old Jan 27, 2004 | 02:12 PM
Red96Lt1's Avatar
If you're talking about the diameter of the pipe, I'm pretty sure it's 2.5"
Old Jan 27, 2004 | 02:14 PM
the bolts that go into the flanges on the y pipe
Old Jan 27, 2004 | 02:37 PM
CMANZ28's Avatar
If i remeber right they are the Metric equivlant to 3/8's. I'll double check when i got out to the shop . I'll let you know for sure tonite.
Chad
Old Jan 27, 2004 | 02:53 PM
There is a stud and a nut, if you mean where the y-pipe connects to the exhaust manifold. The nut is M10x1.5, the studs are ~54mm long.
Old Jan 27, 2004 | 02:54 PM
thanks alot
Old Jan 27, 2004 | 02:56 PM
i just need to figure out what socket to use . .
Old Jan 27, 2004 | 04:46 PM
anybody know what size socket to use?
Old Jan 27, 2004 | 04:57 PM
CMANZ28's Avatar
Yep, shoebox is right again ....Call me stupid but If i remember right it is a standard size socket....i think 5/8...
Chad
Old Jan 27, 2004 | 06:07 PM
i tryed 5/8 its a little bit to big...i tryed a 15 mm it seems to fit but my socket is not deep enough....im gettin frustrated i need to get all that shiet off so i can get my long tubes on...
Old Jan 27, 2004 | 06:43 PM
Socket size is 15mm and I suggest you use a deep 6 point socket only. Also spray it with some penetrant like PB Blaster, first. The studs are notorious for breaking and it's a big headache if they do.
Old Jan 27, 2004 | 09:05 PM
i used a deep 6 point 5/8 and it got those damm bolts off thanks guys...now im one step closer to getting in my jet hots thanks alot guys
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
ChrisFrez
Jan 11, 2015 03:47 PM
WJH'sFormula
Jul 28, 2002 04:51 PM
