What should i get from these mods @ 1/4?
Old Jan 8, 2006 | 07:02 PM
BadCamaro's Avatar
Arrow What should i get from these mods @ 1/4?
Cam 306
Long tube headers
y-pipe 3''
Borla cat-back
LT4 intake
K&N ram air
BBK TB 52
Converter TCI 3200 or 3500
3.73 ratio
stock cultch
Shift kit
Finaly Tune
What do you think in these parts and do u think should I get @ 1/4? The car is daily driver and street racing !!!
Old Jan 8, 2006 | 07:11 PM
97formula808's Avatar
Re: What should i get from these mods @ 1/4?
the lt4 intake manifold will not work w/ the lt1 heads. you sound young.
Old Jan 8, 2006 | 09:26 PM
96flame's Avatar
How do you have a TCI converter and a stock clutch???
Old Jan 8, 2006 | 09:32 PM
EODUSMCR's Avatar
this is a BS post
Old Jan 8, 2006 | 09:36 PM
LUDA0840's Avatar
oooook a clutch and a TC? Wow!!!!
Old Jan 8, 2006 | 09:56 PM
johnnyb's Avatar
Originally Posted by BadCamaro
Cam 306
Long tube headers
y-pipe 3''
Borla cat-back
K&N CAI
BBK TB 52
3.73 ratio
stock cultch
Tune
fixed it for you
Old Jan 9, 2006 | 05:05 AM
BadCamaro's Avatar
Until the gear die after that I will rebuilt gear and install racing cultch.
These mods not install yet. But want to check about LT4 intake with stock head.
Old Jan 9, 2006 | 06:24 AM
Heatmaker's Avatar
Advanced Member
Converters are for Automatic Tranmissions and so are Shift kits.
Manuals don't use them.
Lt-4 intake isn't desinged for LT1 heads... it will not work.
THese should be your mods.
K@N intake
Borla Exhaust
Headers... MAC midlentghs.
Mail order Tune.
There perfect beginner combo.
Old Jan 10, 2006 | 02:31 PM
BadCamaro's Avatar
I found converter TCI 3000. How is it?
Old Jan 10, 2006 | 02:54 PM
JakeRobb's Avatar
Super Moderator
Wow, okay, let me try.
BadCamaro, does your car have an automatic transmission or a manual transmission?
Old Jan 10, 2006 | 02:59 PM
Bersaglieri's Avatar
Listen you need to remake your sig with what year your car is, transmission, and current rear end ratio and current mods. Then we can help you.
Listen to the guys on this board and we will save you alot of time, money, and effort.
Sit back and learn, dont buy anything till you've properly researched it.
First Mods - Cold Air Induction [Lingenfelter, SLP, K&N, Moroso]
Catback [ SLP, Magnaflow, Hooker, GMMG, Borla, Corsa, Mufflex, etc]
Then [Headers, Gears, E-WP, Mail Order Tune [Madwolf or PCM4LESS] 1.6 Pro Mags]
Then [Stall, Cam, whatever else]
-Dustin-
Old Jan 10, 2006 | 03:42 PM
BadCamaro's Avatar
Auto trans
Old Jan 10, 2006 | 04:11 PM
JakeRobb's Avatar
Super Moderator
Okay. You mentioned both a clutch and a torque converter/shift kit, so it was a little hard to tell.
Old Jan 10, 2006 | 04:38 PM
WS Sick's Avatar
With some sticky tires and a 1.8 or better 60 foot time you should run some high to mid 12s.
Old Jan 11, 2006 | 05:04 AM
camaronutt's Avatar
Technically there are clutches in an automatic trans. Maybe he means to replace these with stronger ones
As Bersaglieri said, listen to the people on this board. They are here to help, and teach you and guide you with whatever you will do to your car. I've been modding cars for about 8 or so years and still learn a TON of info on here!!
