What should i Dyno?
Old Sep 9, 2003 | 06:10 PM
Canadian z28's Avatar
What should i Dyno?
What should i Dyno? I have a 95 Z28 with 52,000 miles on it. I have Mac Headers, Off Road pipe, Mac cat-back, LPE cold air intake, and a 160 thermostate. 6 speed.
What numbers shoould i get? i'm hoping for 300rwhp
Old Sep 9, 2003 | 06:21 PM
Z95m6's Avatar
i'll say 290rwhp
Old Sep 9, 2003 | 06:23 PM
Geezer powered's Avatar
275
Old Sep 9, 2003 | 06:24 PM
AxeGrinder30thZ's Avatar
I think you'll be right around 300 or so.
Old Sep 9, 2003 | 06:48 PM
colorchange96's Avatar
my setup did 225 hp. of course that was on 7 cylinders and running real rich. i got accell 9000 header wires and it went to 289. both times the A/F was at the bottom of the rich scale. the consensus seems to be that the egr is stuck open, hence the egr code. i got SJM block off plates and havent installed them yet but should put me over 300. The point is that it all depends on how well the car is running. theres really no way to tell with out getting on the dyno. you might find some problems that you hadnt noticed before. good luck.
Old Sep 9, 2003 | 07:05 PM
NiteRider's Avatar
I say anywhere from 270 to 285.
Old Sep 9, 2003 | 07:11 PM
5.0THIS's Avatar
My dyno numbers below with AS&Ms, RT cat, borla, CAI
Old Sep 9, 2003 | 08:33 PM
Antz97ZNJ's Avatar
id say 280-290 is a safe bet....long tube cars usually are in the 290's
Old Sep 9, 2003 | 08:44 PM
NiteRider's Avatar
Don't worry about what you should be dynoing until you dyno. Some of the numbers you may see on the board are a little odd. "Doctored" some may say.
Old Sep 9, 2003 | 09:41 PM
CANTONRACER's Avatar
People some times forget to mention STD or SAE...so which ever is higher...that is what people use.
Old Sep 10, 2003 | 11:11 AM
IDOXLR8's Avatar
My car dynoed at 292 rwhp and 330 ft-lb with a similar setup.
Old Sep 10, 2003 | 11:14 AM
grygst76's Avatar
400 horsepower
Old Sep 10, 2003 | 11:16 AM
94 CAMRO Z28's Avatar
I would guess around 285. I dont think your gonna get to that 300rwp mark but you'll be close.. Keep modding!
Aaron
Old Sep 10, 2003 | 11:20 AM
Gripenfelter's Avatar
270-280rwhp.
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
