what should i do next?
Old Sep 11, 2008 | 10:27 PM
mr.green's Avatar
hey guys i just got the wires and plugs in a few days ago and what a pain that was....i also got a new fuel filter and the rest of the tune up...so i have right at 600 bucks...what should i do next....i got a little vibration problem and im thinking its the drive shaft..so im thinking about getting a new one...also what should i do next in terms of power, mods in sig also removed spare tire, jack, rear speaker, smaller lightweight battery. thanks for the help
Old Sep 11, 2008 | 11:50 PM
kyleg001's Avatar
Maybe some 1:6 rockers. Not too much left unless you want to really get into the motor.
Do you use your AC? If not put in a replacement pulley
Maybe ,some dress up parts.
Interior components
Shock tower.
Are you sure your vibration is the driveshaft and not worn wheel hubs/ suspension misalignment/ unbalanced tires?
Miss anything on the tune-up rear differential fluid, tranny filter \fluid, suspension bushings, coolant flush, and so many others. .
Old Sep 12, 2008 | 10:05 AM
slomarao's Avatar
1.6rr,ewp, ls1 ds, re balance tires
