what should a expect?
Old Jun 12, 2011 | 12:05 AM
twistedbowtie's Avatar
Question what should i expect?
ive just built a lt1 bored .30 flattop pistons new stock replacement rods and crank. it has the cc305 cam, long tube headers, true daul lm1s, 58mm tb, long story short full bolt ons.
stock heads only have been port matched to gasket.
its a t-56, 3.73 gears.
what kind of power should i expect from this build with a good tune? ive also been thinking about a 150 shot how much would that help? thanks guys
Old Jun 12, 2011 | 12:23 AM
henryz28's Avatar
Re: what should a expect?
With out knowing what pistons you have I would say 320rwhp
Old Jun 12, 2011 | 12:24 AM
Jasonz28camaro's Avatar
you should expect people to make fun of your title....lol
350
350 + 150 shot = 450
Old Jun 12, 2011 | 12:26 AM
the pistons are the mahle hypertectic flat tops. dont have part number with me its at the shop.
thanks i didnt notice the title till you said something.
Old Jun 12, 2011 | 12:49 AM
im realy looking 400 rwhp out of this bottom end. i wanna change heads/intake just dont have the cash yett. whats the best heads (for the price) would this motor with decent heads make 400 ar the wheels?
Old Jun 12, 2011 | 12:53 AM
Yes and the right compression.
Old Jun 12, 2011 | 12:54 AM
Sorry forgot about that cam your using... Maybe close to 400
Old Jun 12, 2011 | 01:01 AM
jason, is that 400 at flywheel with that cam on stock heads? thanks for the help its my first lt1 build
Old Jun 12, 2011 | 03:37 AM
bw_hunter's Avatar
Sorry, you aren't going to be anywhere near 400 rwhp with that cam and stock heads. Probably in the 330rwhp range....
Old Jun 12, 2011 | 09:39 AM
What I meant was maybe close to 400whp with a good set of heads and intake like you mentioned above.
Old Jun 13, 2011 | 02:04 AM
okay thanks. another question is what is the max amount of nitrous do yall think this motor will hold?
Old Jun 14, 2011 | 05:55 PM
95mysticta's Avatar
cc503 with an M6 and a decent set of heads you should see in the 370-380 range with a spot on tune.
Old Jun 14, 2011 | 06:04 PM
henryz28's Avatar
CC503 and send your heads to this man http://elliottsportworks.com/home/?page_id=51; le1 with stainless valves should put you at 400whp. With stock heads I don't see you putting down 400whp you will have to run a cam like the cc306 and I don't know if that will put you at 400whp with stock heads. Power is made in the heads so if you want power you are going to need to spend some money on the heads; lloyd will say port matching and gasket matching will not help much and it can even hurt hp, something about port matching increasing turbulence at the push rod pinch causing hp loss.
Old Jun 15, 2011 | 05:48 PM
thanks guys. i wanted to buy some dart or trick flows then send them off is that pointless or would if be worth it? thanks
does anyone know what stroke i need tobe on tdc when instaling the hub?
or even how to tell which stroke im on?
Old Jun 15, 2011 | 07:01 PM
Expensive but worth it for sure.
