What Sensor Is This? (Picture)
Old May 22, 2008 | 06:41 PM
ENRKyle20's Avatar
Broke it when pulling the engine out some how.
Is it the fuel pump engine oil pressure sensor. So if it looses pressure it turns off the fuel pump?.. I think thats what it is, just want to be posative.
Old May 22, 2008 | 06:42 PM
DelSoto's Avatar
oil pressure
Old May 22, 2008 | 06:45 PM
ENRKyle20's Avatar
Thanks..
Yea. I looked close on AllData and they use the same sensor even tho its listed seperatly in alldata, one said Oil Pressure Sender, the other said Oil Pressire Sender (for Fuel Pump Shut Off)
Shyt, that was a $30 mistake.. I can get a replacement form gmpartsdirect for $33.24.. know of any cheaper ones?
Old May 22, 2008 | 06:56 PM
DelSoto's Avatar
sounds like you bought the first design (93 and early 94)
you need this:
10201491 - F/PUMP SW & ENGINE OIL PRESSURE GA SENSOR
I didn't completely read your orig post. If you can get it for 33.xx, thats pretty cheap. Those guys have some pretty high shipping tho. Might call Jason Cromer. You can find his # on shbox.com.
Old May 22, 2008 | 07:20 PM
Just run down to NAPA and get one.
Old May 22, 2008 | 07:24 PM
DelSoto's Avatar
but that would be too easy....
Old May 22, 2008 | 07:52 PM
ENRKyle20's Avatar
well im in no rush to get it, the motor will not be ready to run for atleast 2 weeks. I just want to get the best price.
Old May 22, 2008 | 09:16 PM
gmpartsdirect + shipping is not going to be it.
Old May 22, 2008 | 09:33 PM
ENRKyle20's Avatar
ok.. nuff said. I will try carquest or napa or autozone..
Thanks guys
Old May 22, 2008 | 10:56 PM
pcgamer4life's Avatar
I snapped mine a few days ago putting headers in, we've got them at work (Autozone) for $20 each. However, there are two different sizes, 1/4" thread, and 1/8" thread (I think those were the sizes) any ideas shoebox? I'm needing one as well.
Old May 22, 2008 | 11:10 PM
ENRKyle20's Avatar
Very good. I will pick on up there
Old May 23, 2008 | 06:45 AM
1994s could have it above the oil filter or behind the intake manifold. The one above the oil filter uses the 1/4" thread.
Old Oct 11, 2008 | 11:14 PM
1995blackttopta's Avatar
i got one from AZ today and it was a hunk of crap.. the one i was replacing due to random low oil pressure during warm outside temps at idle turned into a check gauge light EVERY time i was stopped at idle or going <10mph...
i ended up putting the other one back in since it only shows the CG light once every few days... i hope autozone will allow me to return their crappy part
QuickSilver02
Apr 7, 2015 11:12 AM
Rde Bandit
Mar 21, 2015 10:17 PM
Jazsun
Dec 29, 2014 12:14 PM
