What Sensor is this
Old Aug 16, 2005 | 07:03 PM
c0rey's Avatar
What Sensor is this
Hey i found a broken senor on my car. I have no idea what it is. Its on the passenger side front portion of the intake man. Here are some pics. THANKS!
http://www.domestic-street-scenes.co...in/sensor1.jpg
http://www.domestic-street-scenes.co...in/sensor2.jpg
http://www.domestic-street-scenes.co...in/sensor3.jpg
Old Aug 16, 2005 | 07:29 PM
Jameslt1TA's Avatar
Re: What Sensor is this
Lol i cant believe i dont know what that is...but you car is a 96 so i dont think my car has that sensor...whatever it is.
But anyways were are you from in Nebraska? I work in Kimble.
Old Aug 16, 2005 | 07:39 PM
c0rey's Avatar
Kearney.
Old Aug 16, 2005 | 07:55 PM
crazypurgatory's Avatar
I don't know what it's called but I'm pretty sure it's part of the
EVAP Evaporative Emission Canister Purge Solenoid Valve.
Old Aug 16, 2005 | 08:03 PM
valter's Avatar
I can't believe that it's from LT1. Nothing on pass. side of mine looks like this. How do you know it's broken?
Old Aug 16, 2005 | 08:12 PM
Lightbulb Re: What Sensor is this
I just looked at my EPA sticker and it is the Canister Purge Solenoid Valve.
Just look at your EPA sticker.
Chris G.
Old Aug 16, 2005 | 08:28 PM
valter's Avatar
But it doesn't look like this: http://shbox.com/1/evap_sol.jpg
Old Aug 16, 2005 | 08:44 PM
c0rey's Avatar
ya its mounted in front of the evap can.
Old Aug 16, 2005 | 09:05 PM
Yep what he said.
It is mounted in front of the evap can.
Old Aug 16, 2005 | 10:15 PM
Chris G.
It's the vacuum switch, not the solenoid. It is for monitoring vacuum flow in the system (required for OBD-II). It should be just in front of the solenoid valve on the side of the intake.
Old Aug 16, 2005 | 11:09 PM
Yea your right.
You have everything Rob.
Rob Is this my alarm on the right?
http://pg.photos.yahoo.com/ph/crazyp...&.dnm=1075.jpg
http://pg.photos.yahoo.com/ph/crazyp...1f.jpg&.src=ph
Thanks,
Chris G.
Old Aug 16, 2005 | 11:20 PM
Yea your right.
Thanks,
Chris G.
I have not been under the dash of a 1997. That might be the BCM (it would contain the alarm functions). Does it have a 32 way and two 6 way connectors on it?
Old Aug 16, 2005 | 11:38 PM
It just has the two plugs on it with six wires on each plug.
On one side the wires are biger than the other.
I have a Sliver box under the center console.
I throught that was the BMC that also is hooked up to the air bags.
Also known as "The Black Box".
Thanks,
Chris G.
Old Aug 17, 2005 | 12:01 AM
Thanks,
Chris G.
Might be the DRL module. It has blue and black 8 cavity connectors (they might not all have wires in them).
Old Aug 17, 2005 | 12:15 AM
valter's Avatar
Just went outside, popped the hood, and need to admit - I have this vacuum switch too
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
