What sensor is this?
Old May 24, 2005 | 01:10 PM
defbear's Avatar
On the passenger/top side of the radiator there is a sensor that just pushes into the radiator. Like a plug basically. Is this the coolant temp sensor? Mine was yanked out about a month ago after someone rear ended me causing my fan shroud to pop out of the grooves which yanked down on the wires going to that sensor. I remember pushing it back in and thinking "why didn't it snap in or anything". Yesterday it popped out again while driving only this time when I pushed it back in it snapped in place. Hopefully that fixed it.
Old May 24, 2005 | 01:41 PM
Valkyn71's Avatar
Re: What sensor is this?
Sounds like the coolant level sensor.
Old May 24, 2005 | 04:54 PM
taguy001's Avatar
yes that's the low coolant sensor
Old May 24, 2005 | 06:07 PM
OBE1 95Z28's Avatar
There is a metal spring clip that allows it to snap in place and stay put. Make sure the spring "wire" is there.
Old May 24, 2005 | 10:06 PM
z28forlife's Avatar
Yup its your low coolent senser. Mines been busted for a year telling me that I need coolent, so I just unpluged it and vwala my coolent is fine now.
Old May 24, 2005 | 11:31 PM
taguy001's Avatar
ya they're pretty notorious for giving false low coolant readings, had that problem on my car.
Old May 25, 2005 | 01:18 PM
defbear's Avatar
Thanks for all the responses. Like I said when I plugged it in this time it snapped in place so I think its good to go.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
