What rpm is safe?
Old Nov 27, 2004 | 03:34 AM
96SLPSS's Avatar
What rpm is safe?
When racing, so far i've only hit about 5000 rpm, what should i be revving to, or whats safe? and best performacne in mind.
Old Nov 27, 2004 | 03:38 AM
Loony's Avatar
Re: What rpm is safe?
I remember my auto used to shift around 6k...
Old Nov 27, 2004 | 09:26 AM
96capricemgr's Avatar
The rotating assembly is usually good to the 7K that the pcm can handle so safety is a non-issue, but if you have not had it reprogrammed your rev limit is lower than that anyway. With a basically stock car you are going to want to shift at something over 5500, heck b-body guys are shifting over that with smaller cams.
Old Nov 27, 2004 | 10:13 AM
mebanditws6's Avatar
bone stock: 5700
bolt ons: 5900
After that, it depends on your cam and head work.
Jason
Old Nov 27, 2004 | 12:16 PM
Red-LT1's Avatar
Where would you say to shift with bolt ons plus a CC304, 1.6 roller rockers and double spring valvesprings?
rideordie
Sep 7, 2015 08:22 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
4586
Aug 24, 2015 11:04 PM
Aug 7, 2015 08:52 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
