What pushrod Length for Scorpions 1.7?
I am running stock everything.... and willing to upgrade RRs
This is the set up I have in mind:
Scorpion Roller Rockers scp1026
Beehive Ovate Valve springs 26918
GM pushrod guide plates 14011051
Hardened chromemoly pushrods length = ???
I need to find out what size of studs 3/8? or 7/16?
Valve locks? 648-16 or 787-16 from Compcams.com?
LT4 Valve covers <to reduce valve train noise
What would you guys recomend? I am not gunna race but I want a stout set up... for the street only.
any opinions ideas? info?
thanks in Advance
Marvin
thanks in Advance
Marvin
Re: What pushrod Length for Scorpions 1.7?
LT4 valve covers are expensive and unneccesary. Adjust your valvetrain right and it wont be that loud. Stock studs are 3/8, but 7/16 are a cheap and easy upgrade.
i was told before 7.2, but im not sure, I would like to know also
the part number you have for the beehive springs in jegs says they are "249-26918-16 LS1/LS6 Engines". will these work in the lt1?
i also am learning what i need to know for when i do my scorpion rockers
gonna cost me about $600 in parts
I could check the geometry my self but it would take forever to have pushrod check measuring thing delivered to hawaii and then I will have to order the pushrods I want... Most likely the speed shops here wont have any of that in stock anyway... we talking a month just to get the proper size pushrods not including the fact that I can only work on my days off since its my daily driver!!
can anyone recomend a pushrod lenght?
Marvin
I did my research and for the beehives you can go either 26915-16 or 26918-16... compcams.com has a kit for the 26915-16 but I dont wanna go with the recomended pushrods unless I know the correct length for the LT1.
If you do a search you will find out lots of guys are using Beehives already although the listing is for the ls1/ls6 engines.
Marvin
Originally Posted by Gimpster
Its not always a one size fits all thing dude....
Marvin
I am following your advise and I found these studs at compcams.com
Its part number 4506-16 7/16 and thread lenght is .680 will this fit my stock LT1 head?
thanks
Marvin
Its a standard 7/16 small block chevy stud. So those should work. Stock length pushrod is 7.200
Awesome! Thanks for your info. I will be buying them tonite.
Marvin
I would **THINK** a 7.200 would work. I also thought the same thing on my motor. I checked it to be sure and it ended up I needed a 7.300"
sleeperZ96BT
Sep 9, 2015 08:28 AM
