what pound injectors
Old May 29, 2006 | 03:29 PM
frankthetank078's Avatar
Arrow what pound injectors
hey guys...simple ? what size injectors does a 93 z28 come with and if im putting out 400 to the wheels would i need to change them? thanks
Old May 29, 2006 | 03:33 PM
sabre81's Avatar
Re: what pound injectors
93s had 22 lb injectors. You would probably want at least some 32lb'ers for 400rwhp. 36 or 42s wouldn't hurt either.. Plus you will have room for more power.
Old May 29, 2006 | 03:38 PM
oo ok .... is there anyithing i would need to change to keep the fuel the same like my fuel pump or.....
Old May 29, 2006 | 03:50 PM
sabre81's Avatar
You can get away with the stock pump but most people will recommend that you upgrade. You will need your PCM tuned for the larger injectors;
Old May 29, 2006 | 03:51 PM
alright good...what company should i go with is accel good?
Old May 29, 2006 | 03:58 PM
sabre81's Avatar
I've heard from numerous people that accel are not so good. I have SVO injectors and i have no problems. Might want to search the board and check out some people's comments
Old May 29, 2006 | 03:59 PM
good idea thanks man
Old May 29, 2006 | 04:31 PM
am i sacrificing alof of gas mileage if i go with 32 or should i up it to 36 for future mods?
Old May 29, 2006 | 05:38 PM
yotaman96's Avatar
Lloyd will reccomend the delphi injectors. Combination Motorsports has them pretty cheap. You could also check out racetronix.
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
