At what point are shorties not adequate?
Old Jan 7, 2007 | 07:46 PM
big dave's Avatar
The SLP's I currently have have 1.75" tubes so, are there many gains to be seen by switching over to a longtube header with the same size primary? I understand that with an increase in cubic inches exhaust is more critical. On a basic h/c package will I see much from longtubes?
Old Jan 7, 2007 | 08:32 PM
seawolf06's Avatar
I think header length has just has much to do with making power as the primary length. The best setup is equal length long tube headers with a large diameter. The Kooks seem to be the best out there for the LT1, but are very expensive. I'd only consider them in an all out race setup.
Old Jan 8, 2007 | 04:32 AM
30696bird's Avatar
I have a friend who races his 93 transam ALOT! When he had shorties on he ran consistant 6.30's (1/8) now that he put long tubes on he runs consistant 6.30's. Take that how you want to but it didn't help him. And yes, I was shocked too.
Old Jan 8, 2007 | 10:50 AM
mzgp5x's Avatar
I have the slp shorts on my 1997 383 - D1 Camaro. I thought about going long tubes. But, I'm always taking it apart, and, the slp's seam to give me the clearance I needed. So, I went with a Ramdom dual cat Y, 3 1/2 single pipe mufflex, and, a 3 1/2" qtp cut-out. That really reduced all the back-pressure resulting from the D1.
Old Jan 8, 2007 | 10:54 AM
ulakovic22's Avatar
Depends on the set-up IMO. I had SLP shorties on my LE1 package and when I switched to Pacesetter LT's the car drove better on the low end and I picked up quite a few more ponies as well. Partly because I got rid of the dual cats, but a lot to do with better scavenging.
Old Jan 8, 2007 | 12:05 PM
WS Sick's Avatar
Alot of it has to do with whats after the headers, and I mean immediatly after the headers, in our cars I havent seen a set of shorties that have a good transition from the collector to the cat-back.
In my personnal experience I had 1 5/8ths shorties on my 93 T/A (heads cam, etc) I switched to Hooker 1 3/4 longtubes with a mufflex Y. Best ET with shorties was 12.69 @ 111, best with longtubes and Y no other changes was a 12.28 @ 113 mph. The weather both days was Oklahoma Octobers (mid 50s with wind)
Old Jan 8, 2007 | 02:01 PM
roguedriver's Avatar
"At what point are shorties not adequate? "
As soon as your in the bedroom and she says "Take your pants off hot stuff..."
Bwaaahahahaha.... Sorry, i just couldn't help it....
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
