What plugs and what gap?
Old Feb 18, 2009 | 02:55 PM
MTBSully's Avatar
Used to always run TR-55s gapped at .050" on my stock internalled 95z28. Now i need to know what plugs i should run on my new car.
383 LTx 11:1 CR
LE2 heads
All other mods are in sig but i think these are the only two relevant ones. For the time being, this motor will be N/A.
So, what plugs would you guys recommend? TR6s? Autolites? Also what gap? Thanks guys
Old Feb 19, 2009 | 11:11 AM
MTBSully's Avatar
no one here is running an LE2 setup or similar?
Old Feb 19, 2009 | 11:17 AM
2QUIK6's Avatar
The TR55's at the same .050 gap should be fine. I have some milled LE2 heads on a 350 with about the same compression, maybe a tad more and run the TR55-IX iridiums with .050 gap just fine. YOu would start using a tighter gap when you get into a boosted or NOS application.
Old Feb 19, 2009 | 04:18 PM
BUBBA's Avatar
GM changed their recommendation concerning the gaps from the .050-.060 to .040-.044 on the V8s (around 2003). So depending on the application you'd probably be looking at a TR51X (irradium) witch is already gapped at .040 (however always best to check). If you are other than NA you may be using a different plug, gapl, etc. Or if you have a powerful ignition you might change the gap too.
I don't know why they would go from .050 to .040, however I have an MSD anyway, so my .050 gaps are probably where they should be. JMHOl
Old Feb 24, 2009 | 05:09 PM
MTBSully's Avatar
i heard maybe an autolite 104 would be good?
Old Feb 25, 2009 | 10:01 AM
pcgamer4life's Avatar
An autolite 104 is just a standard copper plug.. bad news bears, imo. Spend the extra on the TR55-IXs, you won't regret it.
KYWes
Jun 14, 2022 06:52 AM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
jayblev95
Jan 6, 2015 11:52 AM
