What is this part on the lower heater hose?
Old Apr 23, 2005 | 08:47 PM
94Z28WP's Avatar
I have a pin hole leak in the rubber hose section of the lower heater hose... I wanted to cut it at the leak and replace the whole section to the water pump with rubber hose... But it has this short crimped section(#13) I've pointed out in the link below... I got the pic off shoebox's page, but I can't seem to find the name of the part for the # listed on his site... Anyone know what it is?
Link
Old Apr 23, 2005 | 08:51 PM
Robs97Z28's Avatar
Re: What is this part on the lower heater hose?
heat core flow control valve. it controls the direction of the coolant. a oneway flow valve.
Old Apr 23, 2005 | 10:45 PM
94Z28WP's Avatar
Ah, thanks... I guess if I replaced that entire hose I'd screw up the flow through the heater core.. Oh well.
Old Apr 23, 2005 | 10:48 PM
There have been people that have removed the flow restrictor and not reported any problems. I'm not advocating removing it, just letting you know what others have done.
Old Apr 23, 2005 | 11:28 PM
jacksprat's Avatar
i blew mine out in a 96z28 and replaced it with a metal pipe and had no problems at all
Old Jul 18, 2005 | 04:29 AM
minnss2002's Avatar
its there so at high rpm's the heater core isnt stressed, i wouldnt remove it
Old Jul 18, 2005 | 11:05 AM
Frank89IROC's Avatar
Part# from GM
You can order the "valve assembly" from a GM dealer. Just cut the old one out and clamp the new one on. It's part# 10188036, about $16.00 from a dealer.
Jlo
Feb 3, 2015 09:41 PM
HectorM52
Jan 31, 2015 07:29 PM
crazypurgatory
Jan 12, 2015 10:45 PM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
