what oil filter u runnin?
Old Jul 29, 2004 | 03:00 PM
Marcus34's Avatar
ive got a 94 trans am and i have flp headers for it. the driver side header wont fit cuz of the oil filter. i have on it right now a fram ph30 which is what is called for. what filter will work or is there a smaller one. plz help
Old Jul 29, 2004 | 03:04 PM
IDAREU's Avatar
Re: what oil filter u runnin?
ac delco makes a shorter filter, but I don't remember the part #.
Old Jul 29, 2004 | 03:16 PM
944v8inDFW's Avatar
AC Delco #PF454 is the short one. I run one because of oil cooler adapter. Then you can tell everyone you have a 454 in your car!
Old Jul 29, 2004 | 03:17 PM
Pasky's Avatar
Im running an AC delco, thier cheap and good quality. I don't understand why people pay $10+ on an oil filter when the delco works just fine.
Old Jul 29, 2004 | 03:18 PM
disco192's Avatar
runnin a 454 in my car
Old Jul 29, 2004 | 03:20 PM
GREGG 97Z's Avatar
K&N HP 3002, its about the best filter you can get for the LT1. $8.99 from Thunderracing, or $9.99 on the shelf at Pep Boys. And the extra money is worth it to me for the sweet 1" socket fitting alone Seriously, it is a very well made filter.
Old Jul 29, 2004 | 03:23 PM
944v8inDFW's Avatar
Originally Posted by GREGG 97Z
K&N HP 3002,
Greg is that the short one?
Old Jul 29, 2004 | 03:24 PM
Red96Lt1's Avatar
K&N here. Yeah, I love the 1" socket adapter.
Old Jul 29, 2004 | 03:31 PM
jkipp84's Avatar
K&N here too... Great filtration and doesn't choke. $9 every 6k-8k miles (German Castrol) is dirt cheap insurance to me.
Old Jul 29, 2004 | 03:36 PM
GREGG 97Z's Avatar
No, the HP 2002 is the short one, the 3002 is about 25% longer. They are the same price so I dont see any reason in getting the 2002. You get more filtering area with the 3002.
Old Jul 29, 2004 | 03:38 PM
andysc's Avatar
Talking Re: what oil filter u runnin?
I run a k&n as I have read many times that the lt1 engines need oil flow, and the k&n is the highest flowing filter there is as compared to most others. I have 184k on my engine, and it is still a good running engine. Now running synthetic oll I'm sure also helps. Sure the gm oil filters rate well, but I feel l I want to do all I can to ensure there is always good oil pressure to my engine. I also change my oil anally, to ensure it is also clean. Doing these two things will get the mileage out of your engine.
later
andy
Old Jul 29, 2004 | 03:55 PM
anaik's Avatar
I have FLP's on mine and have to use the stock short filter. A longer filter will rest against the collector on my car. I figure this will transfer heat from the collector to the oil filter. Don't need that.
Old Jul 29, 2004 | 03:56 PM
944v8inDFW's Avatar
This topic started for header clearence filter. I have not been able to find a K&N short like the PF454
Old Jul 29, 2004 | 04:02 PM
LPE Z convt's Avatar
I second that
Old Jul 29, 2004 | 04:04 PM
DarkRider's Avatar
I too run K&N in my 97 LT1. I usually just pick up the 2002 I will have to check out the 3002 thpough, I didn't even know they made 3002
