View Poll Results: How much rwhp?
340-350
0%
350-360
6.25%
360-370
18.75%
370-380
25.00%
380-390
18.75%
400+
31.25%
Voters: 16. You may not vote on this poll
What numbers will it put out?
Old Jun 20, 2006 | 02:08 PM
Hark_z's Avatar
Well I have had my Heads/Cam for awhile now but have been building the rest of the car up with supporting mods so the H/C package should be in shortly. What kind of numbers do you think I will be putting up?
94 a4
FIPK intake
Pacesetter LT's
3"X-pipe
Dynomax bullets
3" true duals
3.73 gears
MSD 6AL/8.5mm wires
Holley 58 mm throttlebody
NGK tr55 spark plugs
36# injectors
1.6 rockers
INTAKE/EXHAUST
.100"-90/64
.200"-153/118
.300"-207/167
.400"-253/197
.500"-275/214
.600"-284/225
-ported/polished and fully assembled 94 castings.
-The valves are 2.05/1.6
-198cc
-custom grind billet core cam 2.32 duration .6+ lift
-0.039" headgaskets
Take your guess, I can't wait.
Old Jun 20, 2006 | 02:17 PM
Sweetred95ta's Avatar
Re: What numbers will it put out?
225 cfm @ .600 with stock castings Was the exhaust flowed with a pipe? I just noticed you are running 1.60 valves. I guess that could give you quite a bit more cfm.
Old Jun 20, 2006 | 02:24 PM
Hark_z's Avatar
The heads were ported by Mike Blackstone and matched with one of Bret's custom cams. A lot of work went into this setup.
Old Jun 20, 2006 | 02:32 PM
Hark_z's Avatar
How much was your car putting down with the a4 Benji?
Old Jun 20, 2006 | 03:10 PM
ulakovic22's Avatar
I'm not really good with guessing on automatic cars, but with those heads and supporting mods I would think over 400 rwhp easy. Maybe with an auto you will be a little low around 390? I have a small heads/cam package compared to you and I'm at 379 for sure with an M6. I've added an elec. w/p and ported manifold since my last dyno so I'm confident I'm at 390 at least. Good Luck with it!!
Old Jun 20, 2006 | 03:47 PM
I put down 365 rwhp and the car was running like ****. I had a bad opti and the fuel pump (stock) couldn't keep up. I didn't take it back after that, but I will now that I have it all ironed out. I'm hoping for at least 400 rwhp. I would have hoped for at least 390 through the auto.
Old Jun 20, 2006 | 05:18 PM
Hark_z's Avatar
Yeah my vote went to the 380-390 range.
Old Jun 20, 2006 | 06:45 PM
Who is tuning the car? That will make a huge difference also.
Old Jun 21, 2006 | 04:34 AM
JustNO's Avatar
You should see at least 400rwhp with 284cfm heads and that cam.
Old Jun 21, 2006 | 09:54 PM
Hark_z's Avatar
I havent made up my mind yet. Popular tuners in the area are Josh Bommer and Kieth Mccord. I might go with Kieth. You wouldn't happen to be on FAST would you? (f-body assoc of St Louis)
Old Jun 21, 2006 | 10:06 PM
SStrokerAce's Avatar
That setup should be killer. I had those heads here two times and they are some double throwdown stuff for sure. You might be suprised with the HP and TQ numbers you get out of it.
Bret
Old Jun 21, 2006 | 10:54 PM
Yes, I am a member of FAST. IMHO, I've heard the best things about a guy named Tim (mpfi406) or some name like that. He is supposed to be rediculously good. I'm pretty sure he guarantees to tune better than anyone in the area. He does all street tuning though.
Old Jun 22, 2006 | 12:23 AM
Hark_z's Avatar
Is Tim the guy who does Redline's tuning? I wanted to go with Kieth because of the appeal of a dyno tune but they all suggest a dyno tune isnt best for the street..I'm sure I'll be in good hands with whoever I go with.
Old Jun 22, 2006 | 07:01 AM
Yeah, I think Tim is doing Redline's tuning. I know Andy and Chad and I'm pretty sure he's tuned both of their cars. You should be in good hands though.
Old Jun 22, 2006 | 11:37 AM
user 647483's Avatar
I hear nothing but good things about Keith's work on the MOFBA and MOFBODY boards.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Roadie
Feb 16, 2015 10:34 AM
