What now for 11's?
Old Apr 4, 2004 | 03:16 PM
Spanky94's Avatar
What now for 11's?
Here's what my car ran today. And what has been done to my car. What else can I do to work it into the 11's? I already know cam and heads I'm going to save that for the next one. I just would like to know if there is anything else I can bolt on?
Run #1
60' 1.876
330' 5.222
1/8 7.974
MPH 89.04
1000' 10.372
1/4 12.395
MPH 111.74
Run #2
60' 1.866
330' 5.206
1/8 7.965
MPH 88.95
1000' 10.365
1/4 12.400
MPH 110.55
Run #3
60' 1.812
330' 5.1.65
1/8 7.927
MPH 88.89
1000' 10.332
1/4 12.385
MPH 109.55
1995 Z-28 A4
383 10.5 to 1 compression
LT-4 Hot cam kit
LT-4 knock module
LT-4 timing kit
LS-1 injectors
Stock heads with minor porting 2.00 intake 1.56 exhaust
Yank 2600 stall
Meziere electric water pump
1 3/4" Jet hot long tubes
3" piping into Flowmaster
No Cat
all smog removed
58 MM throttle body
K&N cold air intake
Ported MAF
MSD coil
Taylor plug wires
NGK TR55 plugs
Trick flow air elbow
275/40-17 BF drag radials
Custom PCM tune
Still have stock rear end with 3:23 gears
I going to install 3:73 gears, underdrive pulley, subframe connectors, torque arm, and 15 X 10 pro stars with ET Streets in the back and skinnings in the front.
Old Apr 4, 2004 | 03:54 PM
chrism400's Avatar
You are leaving about 2-3 tenths at the starting line. The 3.73 gear will help a bit but don't look for much more than a tenth or two, but a higher stall and slicks would get you darn close! I used to race a 1971 Caprice Classic 406 small block 4.56 gears, 4000 stall 26X10, Dart heads, 11.5 to 1 5.7 inch rods, Vic Jr. It went 12.20's at 108 with 1.69 60 foot times. The car also weighed about 4000 lbs plus me. I remember a Pontiac Firebird 455 1975 model that ran 12.0's at 110. It was all done at the start. Heck, 50 shot of N2O would get you there no sweat!
Basically what I am saying is, you are making enough power now - or at least, you are very, very close. Kick that stall up to 3600 and hook, and you are there man!
Old Apr 4, 2004 | 09:14 PM
Spanky94's Avatar
Thanks, that will be next if the gears and tires don't get me there.
