What is need to do a LS1 intake on a LT1
Re: What is need to do a LS1 intake on a LT1
You are probably referring to the LS1 air intake assembly, right?
I think I've seen it somewhere (or maybe not...), but it must be quite a job, though, since it is much higher.
If you mean manifold, it is impossible for several reasons:
The bolt pattern is different
The ports DO NOT line up ( An LS1 has evenly spaced ports, kinda like a BBC, not two and two together on each bank like an LT1 (Or other SBC)
I believe the manifold-to-head angle is different on an LS1 than LT1
If you mean converting to a lid set up, Im not really sure? I would think you would need a different hood for fitment issues, intake tube to neck down from throttle body to MAF, and if I am correct, you would need to modify, or convert to an LS1 style front bumper. It's costly, and is marginally, if any, better than a SS style intake, or CAI
Originally Posted by 1racerdude
I would pay to see that show. Anybody selling tickets?
Originally Posted by 97Formy
$250 a ticket. You can E-mail me for the details(we have group discounts). David Copperfield is opening for it, he's gonna make the planet disapear. Should make for a good show
That's cheap--- I'll take two.
ahha Sorry guys. I was talking about the air intake assembly. I know there is NO WAY to put the intake maf on a lt1.
I was just thinking if I were to use the Ls1 styly air intake assembly on the LT1 I could the use the area
for the NOZZZZZZZZZZ hookups.
Get a TNT ring,it's the easy way.
