What is my exhaust?
Old Sep 7, 2006 | 12:25 AM
razor02097's Avatar
What is my exhaust?
Ok I changed the oil in my car and got a better view of the exhaust up front. I know there is stock manifolds, stock y pipe and stock cat. The y pipe has compression bends (ribbed) but the cat back has mandural bent 3" tubing into a muffler and duel 2.5" pipes into stock tips. There is no markings on the muffler. I would like to know if anyone can confirm without a doubt this exhaust is bone stock.
here is a vid of the exhaust. Sorry about the volume.
http://videos.camaroz28.com/video/f3...3001694042.htm
Thanks much!
Old Sep 7, 2006 | 01:44 AM
kastraelie's Avatar
Re: What is my exhaust?
Looks and sounded exactly like my stock '93 z28 exhaust. I vote yes.
Old Sep 7, 2006 | 01:48 AM
YZF/LS1 Freak's Avatar
I say stock.
Old Sep 7, 2006 | 10:04 AM
bacatrane's Avatar
Sounds like stock to me.
Old Sep 7, 2006 | 12:56 PM
JoeliusZ28's Avatar
sounds way raspier than my 95 did with the stock setup, if it seems a little louder than normal (i cant tell) i might think the cat has been gutted and had a pipe put through it. You can usually tell that right away by the smell of the exhaust though. I also thought the stock setup was 2.5" instead of 3" but i could be wrong.
Old Sep 7, 2006 | 01:06 PM
KPZ-28's Avatar
Shouldn't the I-pipe be 2 3/4 inches and stepped down to 2 1/2 inches clamped to the muffler and the tailpipes 2 1/4 inches welded to the muffler?
Old Sep 7, 2006 | 06:40 PM
razor02097's Avatar
I dunno
The cat is there. I passed E check when they put it on the dyno thingie so I don't think its gutted.
I'd almost bet money its a 3" pipe going to the muffler and I know for a fact its mandural bent also. The pipes come out of each side of the muffler which is mounted sideways. They arn't welded on either.
Old Sep 7, 2006 | 07:00 PM
Lees94Formula's Avatar
That exhaust is not stock. The cat has definitely been gutted judging by the amount of rasp when you let off the throttle. A stock system will not do that and is much quieter.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
