What MSD Opti Is this? (PIC)
Old May 24, 2008 | 08:56 PM
ENRKyle20's Avatar
Came with my car..
I see the one has a black face, the other red.. the black face one is like $150.. the red face is in the 500's.. whats the diffrence?.. do I have the expensive one?.. Can I tell based on color?..
Old May 24, 2008 | 09:04 PM
caldercay's Avatar
Originally Posted by ENRKyle20
Came with my car..
Well, there is the MSD cap-n-rotor kit, which is the $150 deal, and then
there is the MSD opti/rotor/cap kit, which is the $500 deal. I have the
$150 deal, which looks exactly as your photo. You wont be able to tell
if you have the MSD opti (from that angle) or just the cap/rotor, unless
you remove it.
However, there might be markings on the outside of the opti that would
reveal if it's stock or an MSD opti.
Old May 24, 2008 | 09:34 PM
ENRKyle20's Avatar
ok. I will take the cover off and post some pics.
Old May 24, 2008 | 10:21 PM
Pontiac_97's Avatar
regardless of which one you have, there both garbage!
Old May 24, 2008 | 10:23 PM
ENRKyle20's Avatar
really.. whats good?
Old May 24, 2008 | 10:28 PM
kylersaulsbury's Avatar
ac delco
Old May 24, 2008 | 10:46 PM
brianswimmer23's Avatar
AC DELCO all the way!! its what your engine craves!
Old May 24, 2008 | 11:24 PM
An MSD opti will have the timing adjustment screw.
Old May 24, 2008 | 11:33 PM
ENRKyle20's Avatar
Where would I see this screw if I had it?
so If I have the screw its a MultiSparkDischarge.. if there is not one, its just a MSD brand cap?
Old May 24, 2008 | 11:55 PM
mrmint69's Avatar
On the passenger top by the wiring connector. Mine has an adjustment screw that uses a 13mm socket to turn it.
Old May 26, 2008 | 10:37 AM
ENRKyle20's Avatar
nope. no adjuster. Must just be the MSDs OEM replacemet.
Thanks for the help
Old May 26, 2008 | 11:02 AM
Dadic 78's Avatar
I've had major issues with my MSD units... Went back to Delco, and NO PROBLEMS!
Old May 26, 2008 | 11:03 AM
Thanks for the help
AFAIK, they only make the two replacement models and both should have the timing adjustment screw. If it does not have it, then it's probably not an MSD opti.
Old May 26, 2008 | 11:04 AM
ENRKyle20's Avatar
what else could it be?
Old May 26, 2008 | 11:22 AM
Any old opti with an MSD cap.
