what mods can i do for free on a 94 lt1?
Re: what mods can i do for free on a 94 lt1?
Originally Posted by shock6906
A quick search will render the results you're looking for.
why do so many people on here just want to send you on a search instead of just helping out? if you want to be so impersonal then why bother to reply at all? i mean there's only so many things you can talk about on LT1 Camaros and i'm sure 99% of them have been brought up before, so what would be the point of discussing anything? i'm sure you could find it in a search. i'm new here and i'm not trying to offend anyone, but that's just the impression i have gotten so far.
throttle body coolant bypass, descreen maf, relocate ignition coil to cooler place or put washers between the block and it, to allow heat to escape. air scoop under the left front fender to feed in colder air to your cai filter. much like this
Originally Posted by 2000GTP
The air scoop is a pretty interesting mod.. does that reduce your ground clearance at all, or does it run pretty flush with the radiator air damn deflector?
