What are the major problems?
Old Nov 20, 2003 | 11:27 PM
DanMan35
Guest
Posts: n/a
What are the most common problems with the LT1 engine from 93'-97'? I heard something about Opti-spark, is this a major problem? Are these usually worthy engines as long as you do the regular maintenance checks?
Old Nov 20, 2003 | 11:30 PM
94zLT1's Avatar
optispark is just the usual prob with 93-97 owners...i have replaced mine once but only b/c some retard mechanic dripped coolant on it..if you maintain a LT1 it will last you forever...im on 86K and mine reuns like a beast...oh ya there is that infamous rear intake manifold leak but ive never had it and its a easy fix if it happens..hope this helps.
Old Nov 20, 2003 | 11:51 PM
eyeoutthere's Avatar
The Opti-spark is the LT1’s distributor that is mounted on the front of the engine above the crank pull where it is susceptible to moisture from road spray and leaky Water Pumps.
The water pumps and opti-sparks are the only real problem areas. They usually go out around 70k (but not without warning), cost a couple hundred dollars and a day of wrenching to replace, and will last another 70k or so if installed correctly.
Other than that, these motors are pretty rugged. Unlike my RX7 which keeps breaking all of the ****ing time.
Old Nov 20, 2003 | 11:52 PM
NewbieWar's Avatar
ive got a few places in which i have vacum leaks is this a place intake leak, a vacum leak?
if so how do i determine if i have a leak there and whats the easy fix?
96SilverRam
May 5, 2015 09:56 PM
karnykamaro
Feb 2, 2015 01:37 PM
Jazsun
Dec 29, 2014 12:14 PM
