What kind of times should i expect
Old Jan 14, 2007 | 09:36 PM
chrp3rd's Avatar
hey guys car has the mods listed in my sig and I just wanted to see what everyone else thinks It could run
P.S. the car does have a good tune
Old Jan 14, 2007 | 09:38 PM
396D1SS's Avatar
low 12's with a good 60 ft
Old Jan 15, 2007 | 02:10 PM
Critter's Avatar
12.7 if you hook. i really don't think you could get low 12's.
Old Jan 15, 2007 | 02:53 PM
Javier97Z28's Avatar
Moderator
I've seen hotcam only bolt-on cars go 113 in Florida.... low 12's should be cake w/ that setup if he hooks.
Old Jan 15, 2007 | 03:28 PM
slomarao's Avatar
i think you ll trap 114-115. et= somewhere in the 12's depending on your 60ft. What kind of tires will you be running? What kind of 60fts do you already pull with the car?
Old Jan 15, 2007 | 03:55 PM
The Engineer's Avatar
Based on my past LT bolt-on experience, your mods “can” easily place you in the very low 12s, or possibly high 11s. However, getting everything right with the launch will be the determining factor.
I didn't see any drag radials or ET Streets mentioned in your post, which will be the key to running your full potential. Basically, if you’re getting a 60 ft time of 1.80 or better you will be in the very low 12s.
WD
Old Jan 15, 2007 | 05:59 PM
Sweetred95ta's Avatar
I don't see anything about an aftermarket rearend, so I'm going to guess a 1.8 60 ft and 12.5 @ 114 in the quarter.
Old Jan 15, 2007 | 06:15 PM
Jerm93z28's Avatar
13.3@106
Old Jan 15, 2007 | 07:15 PM
Critter's Avatar
if he runs less than a 12.5 with that setup i would be impressed
Old Jan 15, 2007 | 07:33 PM
chrp3rd's Avatar
Originally Posted by Jerm93z28
13.3@106
man I got that before the heads and cam easily
Yes guys I plan on running et streets so i hope I can hook up
I also have a 99 c5 vette with boltons, yank3500 conv. shift kit and 3.42's it ran a 12.625 @108 on street tires, but the ta definately feels stronger maybe its the gears thanks alot for everyones input Ill keep everyone updated when I return to the track
Old Jan 15, 2007 | 07:36 PM
kline454's Avatar
i say it will run mid 12s
Old Jan 15, 2007 | 07:37 PM
Manual cars ALWAYS FEEL stronger than automatics.
Old Jan 15, 2007 | 07:38 PM
Jerm93z28's Avatar
gotcha. you didnt mention the et streets.
j/w, what did it run on street tires before h/c?
Old Jan 15, 2007 | 07:39 PM
chrp3rd's Avatar
with just the bolt ons 13.1 with et streets
Old Jan 15, 2007 | 08:37 PM
onephatZ28's Avatar
WD
with a hot cam no way
