What kind of time and hps will I see with my setup
Old Aug 13, 2005 | 01:54 PM
SJBlackZ28's Avatar
I just got my motor a 398 LT4 built for nitrous. I will ran 150 shot and was wondering how much I would make in hps and 1/4 without the nitrous and then with it. Here what I have.
398 Ci .40 overbore LT4 Block
Decked/Honed
AFR 220 Heads with 290 intake 207 exc flow
Lunati Nitrous Pistons, 4340 Crank, 6" Rods, Chromolly Rings
Crank was dynamically Balanced on the block with the flywheel and ATI Balancer.
ATI Balancer
AFR Hydra Rev Kit
LT4 Intake match ported
Crane Gold 1.6 adj. RR
upgraded lifters
242/248 @ 112 LSA Cam 575/600 lift
Chromolly Pushrods
Upgraded springs to match cam
Street Twin Clutch and Alum Flywheel
Canton 8qt Oil pan
High Volume Oil Pump/pickup
OBD I PCM tuned for Cam
LT1 Edit with Cable for that PCM\
SLP Headers
cutout
10 bolt 373
what are you guys predicting in my times and hps????
Old Aug 14, 2005 | 07:18 PM
SJBlackZ28's Avatar
Re: What kind of time and hps will I see with my setup
anyone
Old Aug 15, 2005 | 12:52 AM
blackztpi's Avatar
well, wave goodbye to the 10 bolt. street twin will eat that right up. if u must stay 10 bolt, u wont be much for times, cuz u will be feathering it a lot. an oddball guess would make me say mid 11's with that setup, assuming it all works together. this is assuming good traction too. lol
Old Aug 15, 2005 | 01:39 AM
Deenasty's Avatar
SJBlackZ28, the car is going to run, exactly what it ran in Darko's car. This was someones setup already. Both cars are f-body's..Its gonna run exactly the same..
Old Aug 15, 2005 | 04:28 AM
SJBlackZ28's Avatar
Oh yea this is in a built auto LT1, no street twin clutches
Old Aug 15, 2005 | 04:45 AM
JustNO's Avatar
~480rwhp
~450rwtq
I can't guess times because it really depends..
Old Aug 15, 2005 | 01:07 PM
Deenasty's Avatar
I dont know what, but something in that setup was not right if I recall correctly, and Darko was trying to figure it out. Because I remember at the GM vs. Fords event, he was only running like high 12's low 13's at roughly 106mph..
Old Aug 15, 2005 | 01:52 PM
ScreamnChicken's Avatar
I will guess around 450-470rwhp N/A and around 600rwhp on the juice.
I will also guess your ET will be as long as it takes for the tow truck to come out on the track and tow your car past the traps cuz your rear end is gonna explode.
If you had the proper rear end, suspension (you never mentioned if it was upgraded at all) and tire I would say you got a good low 11sec car there.
Old Aug 15, 2005 | 04:00 PM
96LT1TX's Avatar
hah say goodbye to your 10bolt
other than that, 450rwhp if your SLPs are longtubes, and 440rwhp or so if they are shorties.
Old Aug 15, 2005 | 04:18 PM
SJBlackZ28's Avatar
Hey Diego me and rick were talkin about it and he thinks that the cam is wrong but Darko got it custom grind for the motor. His tranny was also going out too so maybe that I dont really know. If it is the cam i might change it. Im still researching it to see what it is. Suspension is brand new front and rears stock springs and shocks. SLP are shortys. I'll be happy with 600rwhp on juice.
Old Aug 15, 2005 | 04:43 PM
Deenasty's Avatar
In order for the car to run the way your are expecting, you need suspension, GOOD Tuning (which I am sure Rick can take care of), and a proper running engine. You cant just pick a cam, and say "This one sounds good". You cant just put parts together and expect them to run properly, many people wish it was that way.
Old Aug 15, 2005 | 04:50 PM
1racerdude's Avatar
Ya need a bigger cam and probably up the compression a bunch to make a bunch of power. The heads will run out of wind about 5500RPM's
Old Aug 15, 2005 | 06:14 PM
JustNO's Avatar
450rwhp = 530 flywheel hp He can see much more than this.. I think he can easy see 550 at flywheel so it will be ~470rwhp.
BTW: Definitaly 12 Bolt rear end required
Old Aug 16, 2005 | 03:03 AM
SJBlackZ28's Avatar
Hey Diego the motor was tune by TEAM ZR1 when they came to the bay area but I got a laptop and LT1 edit so I probably have rick retune it on his new dyno and see what he can do. Darko said they tune it by Data because I guess that how they do it. most likely it will be retune on ricks dyno for sure.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
