What kind of power should I be making?
I was wondering what kind of power I should get and what times you think I should run with this setup. Comp 510/520 230/236 @ 50 cam, 1.5 Roller Rockers, Hooker Longtubes, 28# injectors, 51mm TB, TB by pass, Granatelli MAF, K&N CAI, Comp Cams Rev kit, a set of double valve springs with dampner BUT with out the inner spring, 3" catback, ORY-Pipe, running the TLCC coil per cyl converter, ajustible pressure regulator, CSR electric water pump, UD Pulley, 3:73 gears, custom rebuilt A4 with shift kit, !EGR, !AIR, !CATS, topped off with a madz28 tune. High millage motor (130k)
What's your best guesses?
Re: What kind of power should I be making?
Dartboard says.....
318.45rwhp, 13.4 @ 106 mph.
Dartboard was confused by the input data...it wants to know where you get a 51mm TB? And why you'd cut the springs?
Originally Posted by SS MPSTR
Dartboard says.....
325 hp and 13.4 ish depending - also you should prob be running a stronger valvetrain and would def see some good gains going to 1.6 rockers
Originally Posted by blind527
Man I run a 13.4, soon to be 13.1-2 though with the mods I have.
Dartboard says.....
But you SHOULD be in the 12's. I hope to hit low low 13's with my drag radials and my 150-175# weight reduction since I ran my car last.
I meant to quote him, not you.
Should, could, would...lots of factors affecting what it should run. For all we know, he's racing at 5,000 foot elevation with a DA higher than 7,000 feet.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
