What kind of power should I be expecting from this?
Old Jul 1, 2008 | 12:25 PM
  #16
seawolf06's Avatar
Originally Posted by Caveman1990
What Kind of camp should I run with some LE2 heads that will make 400+ WHP? Sorry Im not that smart when It comes to Heads and Cams.
Look at the Voodoo cams from Lunati. They will be a little rougher than most with an auto trans, but right at home with an M6.
Old Jul 1, 2008 | 01:40 PM
  #17
slomarao's Avatar
Llyod's site is down. He is still in business.
I would go for le2's and a matching cam
Old Jul 1, 2008 | 01:54 PM
  #18
Caveman1990's Avatar
I drive an Auto. What Size of injectors should I run and What Gaskets fit the LE2's?
Old Jul 1, 2008 | 05:29 PM
  #19
osolow's Avatar
gaskets
I ran fel-pro 1074 head gaskets and stock intake gaskets(Thats what Lloyd told me to run).
32lb injectors are about right if you don't plan on spraying. You will have to get it tuned.
Old Jul 1, 2008 | 06:26 PM
  #20
96capricemgr's Avatar
On second thought go with the AFRs.
Old Jul 1, 2008 | 07:34 PM
  #21
seawolf06's Avatar
30lb injectors are good, but you can go with 42lb if you feel the need. Just make sure it is tuned for them before you start it up.
Any LT1 head gasket will fit. The one you choose will depend on deck height, pistons and combustion chamber size.
Old Jul 1, 2008 | 10:49 PM
  #22
MEAN LT1's Avatar
Wow, I forgot the TFS heads were 64cc heads.
Old Jul 2, 2008 | 09:08 AM
  #23
seawolf06's Avatar
So are the AFR heads, IIRC. That's why I am so excited about the Dart heads. 58cc as cast!
Old Jul 4, 2008 | 11:53 AM
  #24
Whats the highest RPM I could run my engine to while still being safe and making the most power?
Old Jul 4, 2008 | 12:01 PM
  #25
ShownomercyZ28's Avatar
6200?
Old Jul 7, 2008 | 08:40 AM
  #26
seawolf06's Avatar
No two blocks are the same. There are too many variables that come into play.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Russ95Z28
Apr 23, 2015 01:55 PM
XtremeLt1
Sep 13, 2002 08:50 PM
