What kind of battery is everyone using??
Old Feb 25, 2004 | 11:10 PM
cmbob67's Avatar
I tested my battery and alternator today because I've had a continuious problems with my battery crappin out after about 5 mins of any type of draw. My alt is puttin out 14.43 , but when my engine is not running my battery only reads 12.37. My car seems slow to turnover when starting up also. Is it that I'm running too weak of a battery? Should I up the CCA's ??? I got this Batt from Advance Auto Parts about a year ago. What size and brand have you all had the most luck with?? Thanks for the info
Old Feb 25, 2004 | 11:14 PM
Xride's Avatar
well I run a optima red top.
dont know about your problem though, sorry.
Old Feb 25, 2004 | 11:16 PM
97WS6SCharged's Avatar
Ditto on the Optima.
Old Feb 25, 2004 | 11:22 PM
Tair's Avatar
lol, car batteries are supposed to read 12v when the car is not running. That's why it says "12v" on the battery, hehe. But anyway, Optima yellow tops are frickin awesome, I've heard the red tops are also good. What I would try before changing out your battery is hooking your battery up to another car, as if you were going to jump start it. Leave your car off, but start the other car up and let it charge your battery for a long *** time. Unhook it and see if you get the same occasional starting problems. Hell, it's free to try.
Old Feb 25, 2004 | 11:25 PM
carlos64030's Avatar
I'm still using my original Delco battery without any problems...knock on wood.
Old Feb 25, 2004 | 11:42 PM
Better yet, drive to Autozone or where ever and have the battery and alternator tested for free.
Old Feb 26, 2004 | 12:10 AM
Brundle's Avatar
wheres the cheapest place to get a optima red top???
Old Feb 26, 2004 | 12:48 AM
Zachz28's Avatar
really they are 12.6 volt batteries if you put a volt meter on ta battey and it read 12.2 in will never start your car. Just a little FYI i pick up in Starting & Chargeing class
Old Feb 26, 2004 | 12:50 AM
PredatorZ28's Avatar
i got a optima yellow top more juice
Old Feb 26, 2004 | 12:53 AM
J's 82's Avatar
running an optima red top, bought a year ago from jegs for like 96 bucks..
works good, just got moved to the trunk..
Old Feb 26, 2004 | 01:44 AM
Type_O_Negative_1320's Avatar
I'm running an Optima red top...Pep Boys sells them for around $110 or so.
Old Feb 26, 2004 | 06:32 AM
IDOXLR8's Avatar
I am using an OPtima red top.
Old Feb 26, 2004 | 07:58 AM
CANTONRACER's Avatar
Odyssey dry cell.
Old Feb 26, 2004 | 08:04 AM
Eliminator's Avatar
In Jegs they are $99. - $119.
Old Feb 26, 2004 | 08:42 AM
justahoe's Avatar
optima red her too
