What intake manifold gasket for ported heads?
Old Aug 11, 2006 | 08:39 PM
speed_demon24's Avatar
I remember reading awhile ago that there are some intake manifold gaksets that have bigger port openings for ported heads. I did a search and nothing came up, does anyone have a part #?
Old Aug 11, 2006 | 08:52 PM
Severous01's Avatar
Re: What intake manifold gasket for ported heads?
my felpro gaskets were opened up pretty good. that's how the guy that ported my heads/intake ported them. used the gasket and went from there.
Old Aug 12, 2006 | 12:44 AM
LT1_383's Avatar
I could be wrong but i remember reading that places like AI don't increase the actual port size. I recomend the use of original GM intake gaskets. They're a little thicker then most aftermarket ones and if your heads have been milled and block decked you might need that little extra to make a proper seal.
Old Aug 12, 2006 | 02:43 AM
I'm not asking if the ports are bigger than stock gaskets, the roof of my port is slightly higher than the gasket, so I need gaskets with bigger port openings.
Old Aug 12, 2006 | 07:33 PM
Anyone, I need to order the gaskets ASAP
Old Aug 12, 2006 | 09:42 PM
z28will's Avatar
dude i just replaced all gaskets on my 95 z28 i also switch my heads witch also have bigger ports the best gasket set i found was the felpro set
Old Aug 12, 2006 | 10:56 PM
Jlo's Avatar
Jlo
Fel-pro 1284
Old Aug 12, 2006 | 11:49 PM
ulakovic22's Avatar
Do a search for LT4 race gasket.
Old Aug 13, 2006 | 12:26 AM
1racerdude's Avatar
Measure your ports. Some gaskets have the size written on the package.
Old Aug 13, 2006 | 01:02 AM
SS RRR's Avatar
If you run LT4 heads then the part number for the larger port intake gaskets from GM is: 12367777
If you have LT1 heads, they'll still work, however the plastic pins will not locate so you'll have to yank them out and use some sealant to hold them in place while placing the intake on the heads.
If the dealer you use is cool then they may let you take one and test fit it onto your head to see if it'll clear (or just draw a template and take it into the dealer).
You'll have to order two. They don't come in a set... at least from GM.
oldschool
Feb 9, 2016 09:21 PM
Noer
Feb 28, 2015 11:29 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
