What the Heck!!??
Old Sep 28, 2006 | 02:24 PM
  #16
Sweetred95ta's Avatar
Re: What the Hell!!??
Originally Posted by shoebox
The opti electrical harness (from side of intake to opti) is different. The different part being the connector on the opti end.
I didn't know that. Nor have I ever done this swap. I was just going by what I remember seeing different between the two different styles. Does he just need to cut his connector off and splice the new one on? Thanks Rob.
Old Sep 28, 2006 | 06:37 PM
  #17
yournamehere's Avatar
Originally Posted by drifter60060
So, it turns out that the factory sent me an LT1 for a 95 and newer Z. I'm thinking that all I need are a cam dowel pin, newer opti-spark and the vacuum hose. If I get that then I think I can use this motor. Can anyone confirm this for me?
Where did you purchase a new LT 1 ?
How much ?
If I may ask.......
Old Sep 28, 2006 | 07:17 PM
  #18
Dave89IROC's Avatar
I would just buy the proper harness extension
https://www.casperselectronics.com/M...Category_Code=
you might need to knock the guides from the connector, but other then that, it is perfect
Old Sep 28, 2006 | 09:18 PM
  #19
DelSoto's Avatar
Re: What the Heck!!??
I am building up an LT4 to take the place of my 94 LT1 and discovered this need for new opti. I also had to purch a new timing cover. What applications would you need the dowel pin to be longet than the stock .650 (why would comp set it at .840)? I installed a comp cam and didnt check it....had no idea I might have to. The engine is all together and back in the car (haven't started it yet). Should I pull it apart and check this measurement?
Thanks!!
Old Sep 28, 2006 | 09:44 PM
  #20
Dave89IROC's Avatar
Thanks!!
YES, too long will destroy the opti
Old Sep 29, 2006 | 06:19 PM
  #21
drifter60060's Avatar
So get this: I got the new opti for the motor. Got to looking at things and it appears that the only problem is that the timing cover is wrong. I'm gonna take the old timing cover and put it on the new motor and use the old distributor and module. Talk about a headache over nothing. That, my friends, is the reason I am not employed at the local GM dealer. Thanks for all the help anyways. But stay tuned, this story ain't over yet.
Old Sep 29, 2006 | 09:10 PM
  #22
DelSoto's Avatar
Pulled mine back apart after confirming with CC that they DO set the dowel .840. Looks to have plenty of room. *shrug* So I left it be.
Old Sep 29, 2006 | 09:40 PM
  #23
So, you are using the 94 cover and opti?
Old Sep 29, 2006 | 09:45 PM
  #24
DelSoto's Avatar
Ordered a 95 cover... they sent a 96 (with crank sensor hole that I had to plug ) and the vented opti. Used a bit of clay as someone mentioned to see if it bottomed out....didn't.
beltrunner
12
Jul 15, 2015 08:39 PM
Noct
Jul 7, 2015 10:27 PM
MichiganSkip
Jul 3, 2015 11:50 AM
cmsmith
Mar 16, 2015 02:34 PM
