What heads to use on a stock LT1 that will also work with no header modification
Old Jan 28, 2004 | 06:09 PM
jaytone's Avatar
I have a stock 94 TA LT1 and dont have the money to have the engine pulled for cams, pistons, etc
My thought is to have new heads, roller rockers 1.6 pro magnums and install headers.
Here are my questions:
1. What heads do you suggest on a stock engine considering that the only other mod will be the 1.6 roller rockers.
2. I have no headers yet, and need to know which header brand whether LT or shorties will bolt up to after market heads.
3. Is it worth changing heads, roller rockers and headers with no other mods. Will there be much performance increase and HP ?
Old Jan 28, 2004 | 06:53 PM
FacelessZ's Avatar
Try doing a thread search there cowboy...
Old Jan 28, 2004 | 08:11 PM
Tony Danza's Avatar
a search isnt even nessesary, you will learn more than one person could tell u here by simply looking through all the posts constantly. You'll learn that way better...... the ways of the force, that is.
Old Jan 28, 2004 | 08:31 PM
Mystic95Z's Avatar
If you have the motor tore down to swap heads you might as well put in a different cam, not that much more work.
Old Jan 28, 2004 | 09:29 PM
marshall93z's Avatar
and all the headers will fit all the heads...
Old Jan 28, 2004 | 09:36 PM
KCFormula's Avatar
Who told you that you have to pull the engine to put a cam in? This is not true.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
Rino1313
Jul 19, 2002 04:31 PM
