what is harder on the timing chaing...
Old Mar 3, 2004 | 07:25 PM
93TA's Avatar
what is harder on the timing chain...
anyone know what is harder on the timing chain - the higher rpm you run w/ a 306 cam or the steeper lobe angles of a ex230/236 cam?
thx
larry
Old Mar 3, 2004 | 08:01 PM
GreenDemon's Avatar
My vote= steeper lobe angles.
To me it seems the steeper rate would produce more tension on the chain. Higher revving could also be problematic but that's common on just about everything in the engine...
Old Mar 3, 2004 | 08:09 PM
93TA's Avatar
that's kind of what i was thinking... steeper lobes = more shock... and shock is what usually does the damage.
i'm trying to decide between the two cams, and i'd really rather not have to buy the vented opti and ed timing set, and just put a new stock set on. got enough stuff(cam, lifters, gaskets, injectors.. etc) and my car only has 25k miles on it and the opti non-vented opti i have only has about 1k miles on it, so i hate to waste it.
Old Mar 5, 2004 | 09:13 PM
93TA's Avatar
anyone disagree, or think that either cam is too much for a stock timing chain?
Old Mar 5, 2004 | 10:22 PM
Mikey 97Z M6's Avatar
Steeper lobes will probably eat the TC quicker than RPM's as stated earlier.
I wouldn't use the stock TC on anything but a VERY mild cam, even milder than my cam.
Mike
BPS
9
Mar 5, 2015 10:51 PM
Alex Barnes
Jan 24, 2015 10:21 PM
ro2207
Dec 4, 2014 06:18 PM
APS95Z28
Sep 5, 2002 10:21 AM
