what happened to that post about window relays to fix motor?
Old Sep 11, 2004 | 10:08 AM
got_hp?'s Avatar
i cant seem to find the post that explained how to add a relay to the window motor circuit. anyone save the thread?
Old Sep 11, 2004 | 10:15 AM
ucnu112's Avatar
Re: what happened to that post about window relays to fix motor?
This one?
Fred
Old Sep 11, 2004 | 12:21 PM
got_hp?'s Avatar
Originally Posted by ucnu112
nah, this one was about adding a standard radioshack relay between the switch and the motor, with a direct power link to the battery.
Old Sep 11, 2004 | 04:48 PM
Don't know. Maybe the guy pulled it because he was going to sell the idea?
Old Dec 12, 2004 | 12:34 PM
Inutero's Avatar
Wow I remember reading that thread.... I really need it now, I can't believe he would pull it like that... What kinda relay was it?
Old Dec 12, 2004 | 01:00 PM
got_hp?'s Avatar
i remember he used a standard automotive relay, its a little square deal with 4 prongs coming out of it.......and he ran a new powe to the battery and ground to the kickpanel area........but i forgot how he had it wired to the window motor/switch wires.
Old Jan 2, 2005 | 01:22 AM
Bone Daddy's Avatar
I still have the .jpeg, if anyone needs it?
[edit]
Here..
Old Jan 2, 2005 | 09:10 AM
got_hp?'s Avatar
thanks, thats what i needed.
Old Jan 2, 2005 | 09:17 AM
BigBird383's Avatar
The fix that is described in that thread that ucnu112 posted seems like it would work, but I only have one question. What about the "auto" feature on the drivers side window which allows you to just push the button once and the windows rolls down without you having to hold the button? In the post someone stated that the window would not stop if you were holding the button and something got stuck in it (i.e.- hand/arm etc.) so does that mean that if you just hit the button too hard and the "auto" feature is initiated then it just wouldn't stop trying to put the window down? Wouldn't that overheat the motor?
Old Jan 2, 2005 | 05:32 PM
Bone Daddy's Avatar
No, it won't. The strip just stops the motor if it's in a bind.
[edit]
Where can I get the relays? Got a part Number?
I'm just wondering which method would be better to repair the motors.
Old Jan 3, 2005 | 02:02 AM
Severous01's Avatar
the only "express" window you need to worry about is the express up. some of the newer cars have express up and they have had accidents with them...but, camaro's dont have express up. and if something gets in the way of your window going down...you got some problems. all you gotta do to stop it is press the up button on the switch.
Old Jan 3, 2005 | 03:27 AM
96SLPSS's Avatar
Is this a common problem with our camaro's? for the passenger side window motor to act 'tired'.
Old Jan 3, 2005 | 09:35 AM
got_hp?'s Avatar
both sides, the motor either wears out quickly, or totally dies..........ive replaced mine about once a year.
Old Jan 3, 2005 | 01:37 PM
96SLPSS's Avatar
Where's the cheapest place to get a replacement motor??
Old Jan 3, 2005 | 02:57 PM
LWillmann's Avatar
I believe this is the thread you're looking for?
http://web.camaross.com/forums/showthread.php?t=269680
Cheapest place to get a replacement motor is Autozone, or other local parts store ~$50.00 with life time warranty on most.
As for the relay, it's probably a standard 30amp automotive relay available at local parts stores and radio shack for ~$5 or so.
